Xlr balanced inputs new question-tavo
tavogee
Sorry, I had another xlr thread somewhere. This is regarding the audio cables I seen online at monoprice. One end of the cable is rca (which I can use on my Onkyo receivers pre-out), the other end of the cable is xlr (which I can connect to my Emo amp). Does anyone in this community know if that arraignment is giving me the true intended purpose of a xlr balanced cable?
LIVING ROOM: Onkyo TX-NR808 Receiver | Emotiva XPA-5 Amplifier | Polk Dsw Pro 660wi Subwoofer | Polk RTi A9 Fronts | Polk CSi A6 Center | Polk FXi A6 Surrounds [5.1 Channel Setup]
Post edited by tavogee on
No, the RCA is unbalanced so the cable is unbalanced. Just stick with RCA<->RCA. -
That is in effect, just an adapter from one to the other, zero benefit.HT: Polk SDA SRS 2.3 main fronts, Klipsch RC-25 center channel, Polk RTi-150 rears, M&K V1B sub, Denon AVR-5800, Samsung 52" LCD, Sony BDP-S550
2 Channel: Carver ALS Platinum, Audio Research LS-2B preamp, Counterpoint SA-100 amplifier, Integra CD player, Denon SL7D tt, TC750 phono pre, Nikko tuner -
Thank you, makes sense now!LIVING ROOM: Onkyo TX-NR808 Receiver | Emotiva XPA-5 Amplifier | Polk Dsw Pro 660wi Subwoofer | Polk RTi A9 Fronts | Polk CSi A6 Center | Polk FXi A6 Surrounds [5.1 Channel Setup]
Defeats the purpose of balanced signal.Sorry, I had another xlr thread somewhere. This is regarding the audio cables I seen online at monoprice. One end of the cable is rca (which I can use on my Onkyo receivers pre-out), the other end of the cable is xlr (which I can connect to my Emo amp). Does anyone in this community know if that arraignment is giving me the true intended purpose of a xlr balanced cable?
Agreed!No, the RCA is unbalanced so the cable is unbalanced. Just stick with RCA<->RCA.DARE TO SOAR:
