In Wall Speakers?
Babber
Babber Posts: 31
edited January 2011 in Speakers
Hi,
I currently have room to construct at 7.1 theatre. I've already bought RTia3's for the front and a CSia6 for the centre.
For the sides and the rears I was going to buy either FXi's or a couple more pairs of RTia3's.
I'm now considering "in-wall" speakers for the sides as it would have a sleeker look.
Are there any recommendations for "in-wall's" that would compliment the RTia3's?
I have an Onkyo TXNR808B receiver that I will be operating at 8 ohms.
Thanks for any suggestions.
Home Theatre
Receiver: Onkyo TX-NR808
Fronts: RTi A3
Centre: CSi A6
Sides: FXi A6
Rears: OWM 5
Subwoofer: TBD
Post edited by Babber on
  • Topper
    Topper Posts: 403
    edited January 2011
    TCi series is timbre matched to the RTi series. (or depending on your timeline, you can also check out the upcoming RT models of the vanishing series :))
  • Babber
    Babber Posts: 31
    edited January 2011
    Thanks Topper. Would the 'LCiRTS F/X' in wall speaker work with my current receiver? The Onkyo receiver can operate at 8 or 6 ohms for the surrounds and this speaker is operating at 4 ohms. Would this speaker compliment the RTia3's that I have in the front?
    And I guess the ultimate question is....are in-wall speakers just as good as traditional speakers?
    Home Theatre
    Fronts: RTi A3
    Centre: CSi A6
    Sides: FXi A6
    Rears: OWM 5
    Subwoofer: TBD
  • mantis
    mantis Posts: 17,329
    edited January 2011
    No they are not a match
    Dan
  • mystik610
    mystik610 Posts: 699
    edited January 2011
    Babber wrote: »
    Generally no. The design of a speaker cabinet/enclosure is an important component of the sound quality of a speaker. Dry-wall has less than ideal acoustic properties. Unless you take the time to carve out and design a wall cavity that is well braced and acoustically 'dead', you're going to have a lot of resonance that will impact sound quality.
    I'm dealing with this now with my car audio speakers, which use the same tweeters and drivers as my LSi9's.
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
  • Babber
    Babber Posts: 31
    edited January 2011
    Thanks for the feedback guys.
    Home Theatre
    Fronts: RTi A3
    Centre: CSi A6
    Sides: FXi A6
    Rears: OWM 5
    Subwoofer: TBD
  • gsxr141
    gsxr141 Posts: 143
    edited January 2011
    i have a quick question. is there an in wall speaker that will match well with front tsi400's, and owm3's for surrounds? i want to replace my rear surrounds (older r1's), and i was going to get another set of owm's. where i have them mounted would be perfect for in-walls.
    50" samsung dlp
    receiver... pioneer elite vsx72txv
    front... polk tsi400's
    rear surrounds... polk tsi100's
    center... polk csi3
    subs... psw150..... 2 of them.
    surrounds.....polk owm3's
  • Babber
    Babber Posts: 31
    edited January 2011
    anonymouse wrote: »
    For surround speakers, especially if your front stage is RTi series, in-walls will sound just fine. Those speakers are effect speakers - you will not have too much information going through them. Make sure you put some insulation in behind them and you will be happy with the sound. I have my whole living room with in-wall speakers and am very happy with them. And I have LSi's and SDA's in other rooms, (I mention this for you to know that I do know what good sounds like).
    Thanks anonymouse. I've been doing research and have been waffling between 'in-wall' speakers and traditional speakers. I have a question into Polk themselves to see if the TC265i's will be replaced by a newer model. My only concern of going 'in-wall' is losing quality sound for the 'live-concert type dvd's' which I watch on occasion..........though my main use will be for movies.
    Home Theatre
    Fronts: RTi A3
    Centre: CSi A6
    Sides: FXi A6
    Rears: OWM 5
    Subwoofer: TBD
  • gsxr141
    gsxr141 Posts: 143
    edited January 2011
    sorry, i thought this question was on-par with the op's question.
    i didn't think it warranted a whole new thread.
    50" samsung dlp
    center... polk csi3
  • Babber
    Babber Posts: 31
    edited January 2011
    I'm still struggling with making a decision to mount either 'in-wall' speakers, FXiA6's, or another pair of RTi A3's or A1's on my sides for a 7.1 system.
    I need to mount them on the wall because I have 3 kids (4 years old and under) that would play havoc on anything on the ground.
    I've attached a diagram (rough sketch not to scale) of my room with my dilemmas.
    Appreciate all the suggestions so far. Thanks.
    IMG.pdf 455.6K
    Home Theatre
    Fronts: RTi A3
    Centre: CSi A6
    Sides: FXi A6
    Rears: OWM 5
    Subwoofer: TBD
