Conrad Johnson PV-5 Tube Preamp
  • dkg999
    dkg999 Posts: 5,647
    edited February 2010
    Lack of remote is my only issue with these great vintage pieces of gear. Call me a lazy a$$ if you want, however I've come to appreciate the value of a remote. Russman's long stick with a suction cup on it does work, but the novelty quickly wears thin!
    DKG999
  • palunter
    palunter Posts: 1
    edited January 2011
    I have one and used it with a CJ M50. Don't expect tight bass or razor sharp highs, but the midrange makes up for it ten times over. Smooth as butter. Female vocals are to die for. More ambiance than you could ever want. Replacement parts particularly capacitors are non existent. Might check with CJ support. Some of the original caps were the best at the time but could not hold up over time.
    Could have done without the tape dubbing. Extra switch contacts that can corrode.
  • inspiredsports
    inspiredsports Posts: 5,502
    edited January 2011
    This is a relatively old thread (12 months), but I ended up buying the PV-5 mentioned with the original poster's help, sending it out to Bill Thalmann at Music Technology for a complete upgrade, and have been enjoying stellar sound waaaay beyond my $1,300 investment (unit, mods, tubes) since. There's more about it in my thread at . . .
    http://www.polkaudio.com/forums/showthread.php?t=96881&highlight=conrad+johnson
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
