just bought new home theatre system.
ijay
hi, i just bought the new polkaudio system.
tsi 400
tsi 100
cs-10
psw-125
with onkyo a/v receiver Tx-Sr608 http://www.us.onkyo.com/model.cfm?m=TX-SR608&class=Receiver&p=i
guys,need ur advice in setting it up. and wanted to knw will it kick sm asses?
tsi 400
tsi 100
cs-10
psw-125
Post edited by ijay on
Should sound very nice. Congrats and welcome to the club.Shoot the jumper.....................BALLIN.............!!!!!
Nice HT setup. Welcome to the forum.
Nice start.welcome and enjoy
What advice do you need in setting it up?
Is there something not in the manual that you'd like our help on?Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Looks like your off to a great start! Welcome to CP.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
That system will be better than what 90% of the people in whatever town you live in own. Welcome to real home theater.
nothing to brainy to be concerned about regarding hook ups, follow the basic instructions and layout. Thats a very balanced system you got there.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Welcome to the club.
Looks like some nice gear to start with you should be very pleased with your purchase.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
on the back of my sub theres an option for phase(0 or 180) what does that mean? which one should i select. and generally what is the ideal position of sub in the room?
thats going to sepend on your room. Subs can be funny things they way they work in different rooms. play around with the setting and see what you like. try the extremes (0, then full 180) If you dont notice a difference, that means the phase has no bearing on your room. If it makes a significant difference, welcome to tweaking something to optimize the best sound. It will consume you.
either way play around and enjoy it......whatever the setting you leave it on will not be a huge gamechanger.Living Room 2 Channel -
if i wanted to play 3D movie on this system. what things do i need? the receiver says that it supports hdmi version 1.4a so this means its 3d compatible, do i need a 3D projector or just a simple projector?
please tell all the things i need. -
Ijay, everything you need will have to be 3D compatible from your Blu Ray Player, the Movie and the TV or Projector you will use....the good news is you have the receiver already.
Plus, you will require some fancy glasses to boot. Go over to your nearest Best Buy just to have a look. At the very least you can get a better idea of how it works.
The good news if you buy a 3D compatible TV (usually an LED - 240Hz) is that it also gives a spectacular image when you are viewing 2D 1080P.
JuanR -
what r the things i need to look in the projector before buying? it should also be able to play 3D movies.
Congrats.
Hook everything up and run the Audysey setup. After the setup, make sure all speakers set to small.
Also, make sure the Audysey mic is at listening level. I used a tripod.
The only thing that was confusing to me is that I have a 5.1 setup with 2 speakers in the back, but you have to set those up as sides.~Dan
Projector: Epson 705HD on 106" DaLite
TV: Samsung 50" Plasma PN50B550
Receiver: Onkyo 607
Fronts: Polk 1000i
Center: Polk Csi40
Rears: Polk Fxi30
Sub: Velodyne Minivee 10
PS3 and Xbox
