just bought new home theatre system.
ijay
ijay Posts: 4
hi, i just bought the new polkaudio system.
tsi 400
tsi 100
cs-10
psw-125
with onkyo a/v receiver Tx-Sr608 http://www.us.onkyo.com/model.cfm?m=TX-SR608&class=Receiver&p=i
guys,need ur advice in setting it up. and wanted to knw will it kick sm asses? :p
Post edited by ijay on
  • Sherardp
    Sherardp Posts: 8,038
    edited December 2010
    Should sound very nice. Congrats and welcome to the club.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Nice HT setup. Welcome to the forum.
  • NotaSuv
    NotaSuv Posts: 3,871
    Nice start.welcome and enjoy
  • nguyendot
    nguyendot Posts: 3,594
    What advice do you need in setting it up?
    Is there something not in the manual that you'd like our help on?
    Main Surround -
  • Knucklehead
    Knucklehead Posts: 3,602
    Looks like your off to a great start! Welcome to CP.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
  • ohskigod
    ohskigod Posts: 6,505
    That system will be better than what 90% of the people in whatever town you live in own. Welcome to real home theater.
    nothing to brainy to be concerned about regarding hook ups, follow the basic instructions and layout. Thats a very balanced system you got there.
    Living Room 2 Channel -
    Upstairs 2 Channel Rig -
  • aboroth00
    aboroth00 Posts: 1,107
    Nice. Time to break out that camera!
    2Ch Tube Audio Convert
  • djperez81
    djperez81 Posts: 388
    Welcome to the club.
    Looks like some nice gear to start with you should be very pleased with your purchase.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • ijay
    ijay Posts: 4
    on the back of my sub theres an option for phase(0 or 180) what does that mean? which one should i select. and generally what is the ideal position of sub in the room?
  • ohskigod
    thats going to sepend on your room. Subs can be funny things they way they work in different rooms. play around with the setting and see what you like. try the extremes (0, then full 180) If you dont notice a difference, that means the phase has no bearing on your room. If it makes a significant difference, welcome to tweaking something to optimize the best sound. It will consume you.
    either way play around and enjoy it......whatever the setting you leave it on will not be a huge gamechanger.
  • ijay
    ijay Posts: 4
    edited January 2011
    if i wanted to play 3D movie on this system. what things do i need? the receiver says that it supports hdmi version 1.4a so this means its 3d compatible, do i need a 3D projector or just a simple projector?
    please tell all the things i need.
  • JuanR
    JuanR Posts: 718
    edited January 2011
    Ijay, everything you need will have to be 3D compatible from your Blu Ray Player, the Movie and the TV or Projector you will use....the good news is you have the receiver already.
    Plus, you will require some fancy glasses to boot. Go over to your nearest Best Buy just to have a look. At the very least you can get a better idea of how it works.
    The good news if you buy a 3D compatible TV (usually an LED - 240Hz) is that it also gives a spectacular image when you are viewing 2D 1080P.
    JuanR
  • ijay
    ijay Posts: 4
    edited January 2011
    what r the things i need to look in the projector before buying? it should also be able to play 3D movies.
  • dvran
    dvran Posts: 280
    edited January 2011
    Congrats.
    Hook everything up and run the Audysey setup. After the setup, make sure all speakers set to small.
    Also, make sure the Audysey mic is at listening level. I used a tripod.
    The only thing that was confusing to me is that I have a 5.1 setup with 2 speakers in the back, but you have to set those up as sides.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
