Microsoft Outlook keeps crashing! Please HELP!
hearingimpared
Well I ran one of those online registry & disc clean programs a little while ago and since then, Outlook crashes at least once a day! Tried to do an undo of the fixes but no dice.
I send the error report to Microsoft and all they come up with is to upgrade Outlook.
I'm running Windows XP w/Outlook 2002.
Other than deinstalling and reinstalling it does anyone have any ideas?
Thanks in advance,
Joe
Thanks in advance,
Joe
Post edited by hearingimpared on
You might not have to "deinstall" (or what we in the biz call "uninstall"), just install on top of the existing Outlook - Outlook Install might even have a "repair" option for this very purpose. It'll clean up any files that got corrupted or removed but likely not mess up your setup.If you will it, dude, it is no dream.
Just crashed again for the second time today!
Bob will it keep my address book and preference the same if I install the existing Outlook?
BTW I've been out of the biz for 10 years so forgive the error in verbiage! -
I had so many problems with Outlook, I switched to Mozilla Thunderbird, it seems to be more stable than Outlook.
IIRC Thunderbird will import all of your settings as well.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
try a
" boot from last known good configuration " ( google search for more info ) -
hearingimpaired wrote:Bob will it keep my address book and preference the same if I install the existing Outlook?
It SHOULD, but that doesn't mean it will. Seems worth the risk; nothing you do at this point is going to be foolproof, considering what a crappy state you're in. Of all your options I'd say it's the one most likely to save your settings.Knucklehead wrote: »I had so many problems with Outlook, I switched to Mozilla Thunderbird, it seems to be more stable than Outlook.
Unfortunately most companies that use the Outlook system won't let you sync with anything BUT Outlook.
Joe, if you're just using it for personal reasons, I agree with Knucklehead.If you will it, dude, it is no dream. -
**cough cough....MAC....cough cough**Living Room 2 Channel -
Schiit SYS Passive Pre. Jolida CD player. Songbird streamer. California Audio Labs Sigma II DAC, DIY 300as1/a1 Ice modules Class D amp. LSi15 with MM842 woofer upgrade, Nordost Blue Heaven and Unity interconnects.
Upstairs 2 Channel Rig -
Prometheus Ref. TVC passive pre, SAE A-205 Amp, Wiim pro streamer and Topping E50 DAC, California Audio Labs DX1 CD player, Von Schweikert VR3.5 speakers.
Studio Rig - Scarlett 18i20(Gen3) DAW, Mac Mini, Aiyma A07 Max (BridgedX2), Totem Mites -
Hey Joe (Where you going with that gun in you hand ),
I think your stuck with uninstalling & reinstalling Outlook unless that online registry cleaner made a backup of your registry. BTW never ever use any online tools like that again there just too risky. You might try just Reinstalling Outlook over your existing Outlook but back up all your Outlook stuff first and if that doesn't work I would do the following.
1. Backup all your Outlook stuff i.e Contacts , E-mails, etc...
2. Uninstall Outlook completely.
3. Download CCleaner (It's Free and they also have a great defrager) Install it, Run it (It does give you the option of backing up your registry every time just in case)
4. Reinstall Outlook and all the stuff you backed up from step 1.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
You could try a repair install instead of uninstalling completely. Should be an option if you go to add/remove programs and then try to remove it. Is it a part of Office, or did you purchase it separately?Ludicrous gibs!
*cough**cough*wind up toy*cough**cough*
Joe,
You should be able to just upgrade Outlook 2002 to something newer. It should save all your settings and your address book.
However, I gotta agree with what's been posted. Download Thunderbird or Seamonkey from Mozilla and use that to manage your mail. It's a simple SMTP client vs all the "enhanced" bs that M$ puts in Outlook. It's less vulnerable to malware and because it's fairly unused, there's security through obscurity with it too.
I use Seamonkey. It's essentially the old Netscape suite with modern functionality. I manage 7 different email accounts from the same Seamonkey console with ease. Thunderbird should do the same.
Besides, Outlook is notoriously buggy and vulnerable. Exchange is the better option from M$ but usually, to realize the full potential, you need to be in a managed environment for Exchange. It doesn't do so hot standalone.
But yeah, for personal stuff, keep it simple. Outlook is overly complex IMO for the simple task of checking emails that consist of SPAM, 90,000 forwards from friends and family with the latest funny/cute picture/email/video and the occasional Nigerian scammers. I'd move to a free client that is easily updateable and upgradable. If you do switch clients and things get ugly or something you know how reach me. At the very least, upgrade Outlook 'cause I know there are issues with 2002 that M$ didn't patch but rather just fixed in later versions. That might be a costly upgrade though, I dunno. I haven't used Outlook since I was in college and forced to use it by the school.Expert Moron Extraordinaire
Thanks loads fellas for the feedback. I've been using Outlook for years and never had a problem until now. I'm going to give your suggestions a shot. . . that being said, John I know where you live Bro! LOL!!!
One other thing I might try is that I have a logmein account. Sal has logged onto my PC a few times in the past to fix an eff up or two. Maybe I can persuade him when he's not busy to log into my PC and look around as I might just be overlooking something obvious.
Thanks again fellas,
Joe -
hearingimpared wrote: »One other thing I might try is that I have a logmein account. Sal has logged onto my PC a few times in the past to fix an eff up or two. When he does, I wind up with hotlinks for "midgetporn.com" but hey, can't complain about the cost.......... Maybe I can persuade him when he's not busy to log into my PC and look around as I might just be overlooking something obvious.
Joe
aaaaaaaaaaaaaaaaand fixed!!Living Room 2 Channel -
If you've been using the same install of Windows XP for more than 5 years, you would probably greatly benefit from a complete wipe and re-install of your OS. I know its a lot of work, but it would feel like a new machine again. Give you the chance to streamline things and only install the software that you still use. I do it every 2 years or so.For rig details, see my profile. Nothing here anymore...
*cough**cough*get rid of the POS Outlook*cough**cough*
Thunderbird, Gmail....just about anything is better than Outlook IMHO.--Gary--
...Exchange is the better option from M$ but usually, to realize the full potential, you need to be in a managed environment for Exchange. It doesn't do so hot standalone.
A scaled down MS messaging application is Windows Mail or Windows Live Mail (formerly Outlook Express), which is free; info and download here.
Otherwise I agree that if this is just for personal use Outlook may be overkill and a slimmer client mail app would be better.____________________
Pool: Atrium 60's/45's -
I may have to look iinto this myselfPio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
do you have any upgrade versions of office available to you ?
Go into options and disble all plug-ins. Outlook crashing in your scenario can be related to some other program that was effetcted by registry cleanup. I had similar problem and the issue was due to antivirus plug-in.-izafar
Goldenear Technology Triton 1 - Benchmark AHB2 - Benchmark LA4 - Auralic Vega - Auralic Aries Mini - Marantz TT-15S1 - Clearaudio Nano -
I put 90% of my money on malware.
Run this free program and see if it finds anything. I bet it does.
http://www.malwarebytes.org/mbam.php
Or try ccleanerHT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
Before you do anything, in Outlook, go to File and look for IMPORT/EXPORT. You should be able to export all of your mail and contacts to a backup.pst file. Then if you lose all your stuff in a reinstall, all you have to do is import that .pst file back into Outlook after you re-add your e-mail account.Equipment list:
Onkyo TX-NR3010 9.2 AVR
Emotiva XPA-3 amp
Oppo BDP-93 Blu-ray player
Epson 8500UB 1080p projector
Elite Screens Sable 120" CineWhite screen -
Try this:
Start-> Run; "C:\Program Files\Office 11\Outlook.exe" /resetnavpane
If you do uninstall make sure you back up your .pst file before doing so.Shoot the jumper.....................BALLIN.............!!!!!
AudioGenics wrote: »do you have any upgrade versions of office available to you ?
Not for free.:frown: -
I don't see anything under option to disable plug-ins. What am I missing? -
Try this:
Sherad is there supposed to be a forward / before resetnavpane? BTW what is "resetnavpane?" Also I think the cleanup and registry cleaner I used did mess with the .pst file. -
hearingimpared wrote: »Sherad is there supposed to be a forward / before resetnavpane? BTW what is "resetnavpane?" Also I think the cleanup and registry cleaner I used did mess with the .pst file.
Type this instead
Start--->run
Outlook.exe /resetnavpane
In windows Vista or Windows 7 just go start and type it in the search programs and files space. This should reset Outlook and allow you in.Shoot the jumper.....................BALLIN.............!!!!!
If you feel your .pst file is corrupt you can run scanpst.exe which will repair a corrupt header file if it is in fact damaged. To so check this out
http://www.sevenforums.com/tutorials/73585-pst-file-corrupted-repair.html
I've had crashes in Outlook also, so here's to hoping both of these help you. I'm using a version the professional version of Office 2010 now that I got from the "Underground". Fully functional, but shhhhh don't tell anyone. Let me know if this helps.Shoot the jumper.....................BALLIN.............!!!!!
What Sheradp said. If I have problems with a lookout install that delivers mail locally, it nearly always ends up being either a problem with the pst file or some kind of malware. Copy off your pst, then run scanpst. Also, if you've been running it that long, what size is your pst? I may simply have gotten so large that it's causing memory exhaustion.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: Aural Thrills
Digital: Pioneer DV-79ai
Pre: Conrad Johnson ET3 SE
Amp: Conrad Johnson Evolution 2000
Speakers: SDA 2.3TL, heavily modified -
Well beings that I've been out of the, as Bob put it, the "biz" for so long, I'm hesitant to do any of the above. Perhaps you fellas could dumb it down to my level which is close to computer illiterate these days.
