Another silly question...
On the Monitor 70's there are two speaker terminals...does it matter which set i use top or bottom?
Post edited by xgnarlycorex on
Welcome!
    edited December 2010
    nope......leave the jumper in place and use either one.
    Polk Audio Surround Bar 360
    Mirage PS-12
    LG BDP-550
    Motorola HD FIOS DVR
    Panasonic 42" Plasma
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    RT8t's & Wharfedale Diamond II's[/SIZE]
    Life is one grand, sweet song, so start the music. ~Ronald Reagan
    Define jumper?
    its the plate that provides connectivity to both sets of speaker inputs. If you were to bi-amp your speakers you would remove the jumper, but that requires external amplification.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    The metal strap between the top and bottom posts, make sure it's not removed.
    My receiver has speaker terminals that say "Bi-Amp" on them they are the same terminals that I would use for the Rear Surrounds if I decided to go 7.1...would I still need external amplification to bi-amp? What benefits does Bi-amping give me?
    You could, but I wouldnt recommend it, you wouldnt be gaining anything by bi-amping from your receiver, im assuming then you would use the other outputs for a 7.1 set-up. I dont bi-amp my speakers so maybe someone can chime in that does and they can give you their thoughts on it.
    Mirage PS-12
    LG BDP-550
    XBOX 360[/SIZE]
    Office stuff
    Allied 395 receiver
    Pioneer CDP PD-M430
    I'd probably rather go 7.1 anyways....if i had the room for it.
Welcome!
Welcome!
