Another silly question...
xgnarlycorex
On the Monitor 70's there are two speaker terminals...does it matter which set i use top or bottom?
Post edited by xgnarlycorex on
nope......leave the jumper in place and use either one.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
Motorola HD FIOS DVR
Panasonic 42" Plasma
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
RT8t's & Wharfedale Diamond II's[/SIZE]
Life is one grand, sweet song, so start the music. ~Ronald Reagan -
Define jumper?
its the plate that provides connectivity to both sets of speaker inputs. If you were to bi-amp your speakers you would remove the jumper, but that requires external amplification.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
The metal strap between the top and bottom posts, make sure it's not removed.HT SYSTEM-
lsi 9's -
My receiver has speaker terminals that say "Bi-Amp" on them they are the same terminals that I would use for the Rear Surrounds if I decided to go 7.1...would I still need external amplification to bi-amp? What benefits does Bi-amping give me?
You could, but I wouldnt recommend it, you wouldnt be gaining anything by bi-amping from your receiver, im assuming then you would use the other outputs for a 7.1 set-up. I dont bi-amp my speakers so maybe someone can chime in that does and they can give you their thoughts on it.Polk Audio Surround Bar 360
Mirage PS-12
LG BDP-550
XBOX 360[/SIZE]
Office stuff
Allied 395 receiver
Pioneer CDP PD-M430
I'd probably rather go 7.1 anyways....if i had the room for it.
