Bass Advice. PSW650 or PSW505?
jdavy
Hi,
I am wanting to upgrade my HT system with a better bass. I am using a psw350 with my RT800i, CS400i and FX500i system. My room is large 20*12*8 with a open stairs next to the system that takes you up half a flight to the next level of the house. That makes the ceiling at that point, 14 or so feet tall. Which would you recommend for this settup? I am looking at the 12" PSW505 and the PSW650. Both are available in my area eventhough the PSW650 is now being discontinued.
Help!!
What do you like/recommend and why.
Thanks in advance to everyone on the forum, Polk employees included. You are all great.
James
Help!!
James
Post edited by jdavy on
From my older post:
"I think the 505 is better.
I just recently asked a similar question regarding 505 vs. 650, and doc had this to say "The 505 is latest generation - more power, better driver, slot loaded."
505 freq. response is 23-160hz
650 freq. response is 25-180hz
505 amp is 300watt continuous (460 peak)
650 amp is 165watt continuous (250 peak)"
Regards,
PolkThug -
Thanks for the information but it still seems like the PSW650 is the top sub for Polk and is being replaced by a LSWi (model number may not be correct) that is a 2*10 for the lsi series. Looking for more commets.
Thanks. -
The PSW-650 is an *average* performer.....
Hits about 105-106db on AVERAGE** and not a lick below 28...
It's not the most accurate bucket in the fish camp either- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
