Unstrap those amps for your SDA's
Toolfan66
Well I unstrapped my amps and have a AI-1 cable in the mix. I have always had to strap my neg's on my amps for my SDA's.
Well if one has not heard the SDA's without a amp or amps that did not have the neg's strapped you have no idea on what your missing. The AI-1 Cable gave the SDA's more life then I thought was possible.
The SDA effect is perfect in every way and with my new amps well it = audio heaven...
Get off your arse's and get to building yourself a AI-1 Cable your speakers and ears will thank you..
Post edited by Toolfan66 on
Told ya.Political Correctness'.........defined
President of Club Polk -
I should also say I unstapped my Adcom GFA-5802 as well and I still could not beleive how much the strap took away from the clarity in sound. I personally think this is the one cable Polk should have available for the SDA enthusiast.
Yea I know they could make one, a better one at that but not all people have the skills to do so.. -
What is the AI-1 cable? Can we argue about it?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Well before I hooked it up I banged it on the table for better clarity..
Pics or it didn't happen
Ben -
I'm listening to Diana Krall right now and it is fantastic much much better then the A9's.
Not knocking the A9's as I was in awe of how they responded to these amps.. -
Time to move the adcom to the HT rig and get that E*%^#*^ out.
too bad it would be such a pain to try out the LSI's on those amps... most likely for the best considering it would end up costing me a ton of money!
Yep but I'm thinking of putting the Adcom in the bedroom with the 1C's -
TOOLFORLIFEFAN wrote: »Yep but I'm thinking of putting the Adcom in the bedroom with the 1C's
And strap it. Lol -
grimmace19 wrote: »too bad it would be such a pain to try out the LSI's on those amps... most likely for the best considering it would end up costing me a ton of money!
It would be worth every bit of the hassle and gas.. trust me these are the sweetest amps I have yet to have my ears on and I'm not sure it can be topped.. -
You have 1Cs in your bedroom? Must be bigger than my HT room then!
Enjoy the space. Our house is a 110 years old and the rooms are pretty small--but many?
cnh
It's not that big but it gives them a home when I don't put them in the mix of the 2 channel and the wife likes them better when she wants to watch TV and just relax in there.. -
cnh
Add beams knock down walls....I did:biggrin:2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
TOOLFORLIFEFAN wrote: »Well before I hooked it up I banged it on the table for better clarity..
Sounds like something someone else on this forum would do,to protect his identity I'll just call him 'short wick'. -
Sure we can. I think it has something to with steak sauce doesn't it.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Sweet....I knew someone would be able to help me.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
What the %uck is "unstrapping"? I'm using a Carver TFM-45 with my 1C's and a custom made effect cable (single plug). Can I "unstrap" mine and hear even more magic? What is this unstrapping you speak so enthusiastically of?SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
first darqueknight, and now toolFFL. maybe it's time for myself to look into this. i've got my 5802 strapped just like them gangsta's 'roun' the co'nuh.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
7.1 SURROUNDS: RTI6'S
XBOX 360WiiPS3/blu-rayTOSHIBA HD-A35 hd dvd
http://polkarmy.com/forums/index.phpbobman1235 wrote:I have no facts to back that up, but I never let facts get in the way of my arguments. -
And the 5802 sounds great!!!! Wait till you build yourself a A1 cable, Yes it is that much better...you don't notice it till you do it.. -
you strap the grounds together if you have a non common ground amp. -
Could someone make this real simple and provide a "strapped" diagram please? And what is an AI-1 cable? How does it differ from the stock cable?
Oh, and I'm bi-amping my SRS's...so anything different with this "strapping".?
JoeAmplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96. -
Well I have read that some people think tubes can take away from the Bass compared to a SS amp, well these amps lack nothing as a matter of fact they are deeper and tighter then my Adcom but these amps cost four times as much, so I doubt this is a fair comparison as these tube amps are very efficient.
hate to admit it, but i am with joe. not quite sure what the ...or should i say HOW the original polk a1 does what it does. normally i've just sorta skimmed over those threads. i entered into darqueknight's to admire the craftsmanship. i didn't realize it could be as inexpensive as has been declared.
time to get my learn on...again.
ONKYO TX-SR805
CENTER: CSI5
MAINS: RTI8'S
SURROUNDS: RTI8'S
TFLF - Just relax and listen for awhile before you start thinking about different tubes and other stuff. You should get some Herbie's tube dampers now that I just said that.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
joeparaski wrote: »Could someone make this real simple and provide a "strapped" diagram please? And what is an AI-1 cable? How does it differ from the stock cable?
Joe
Not sure it differs from the stock cable as long as you have a common ground amp,but taking a non common ground amp and strapping the neg's together and forcing it to be a common grond amp I think takes away from what the amp should be doing..
I'm not sure about it as I have never had a common ground amp but I do know that unstrapping these amps gave everything a new life..
others may chime in about it, but the whole strap the negs and your good to go saying is out the window for me. Sure it will get someone by for the time being but making a AI cable is not that exspensive.. -
Yea I'm going to keep them as is for a few as I still owe some money for these amps but they will be paid off in a couple of months. so I have some time and I also have a couple of small projects to finish as well..
Herbie's is on my short list. Next big upgrade will be a SACD/CD player. -
What tubes are they?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
