Crossover help needed!
Hey guys! iam new to the club and i want 2 thank in advance 2 all of you that help me out.
Well first of all iam new to the crossover setup so i will really thank if you can tell me whats the recomended crossover settings for:
L-R: RTI A1
CENTER: CSi A4
SUB: PSW10
SORROUND: RM6750
Reciever: Onkyo TS-SR608
IAM BIAMPING THE FRONT SPEAKERS
i Used the Mic and it gave me:
L-R: 40HZ
CENTER: 40HZ
SORROUND: 90HZ TOTAL!
IS THIS OK OR AM I MISSING SOMETHING?
Post edited by williamspicazo on
  • ben62670
    ben62670 Posts: 15,969
    edited December 2010
    40 is way to low for a center, and it is also low for your mains. Manually set them at 80hz all around.
    Merry Christmas
    Ben
    Ben
  • williamspicazo
    williamspicazo Posts: 4
    80hz got it Ben! thanks for the feedback! and Merry Xmas 2 u 2!
  • ben62670
    I think you will enjoy it more at 80. It takes a load off the speakers and the AVR.
    Ben
    Ben
  • williamspicazo
    any suggestions on my sub? it has a knob from 80-100 all the way 2 160hz
  • aboroth00
    aboroth00 Posts: 1,108
    Turn the crossover on your sub to OFF. If it does not have a off setting crank the crossover on the SUB all the way to 160hz. Set the crossover on your receiver all to small for all the speakers and 80hz for the sub as well if there is a function for that..
    2Ch Tube Audio Convert
  • williamspicazo
    Awesome! thank you all for your help!
