Hookup of RTi4 and RM87
fslsf
I have an RX-V867 with Polk Audio RM87 speakers and PSW111. I also have a couple of RTi4 speakers. I was thinking of adding the RTi4 as High fronts surrounds for the same room.
Question: Is it possible to add the the vintages RTi4 and RM87 to have 9.1 speakers setup in the same room.
If yes! Can you tell me the setup (wiring) for the RTi4 to RM87?
Post edited by fslsf on
I believe your yammy is only capable of 7.1 and you need at least a 9.1 receiver of being able to setup 9.1 in your room2Ch Tube Audio Convert
With that said, there is nothing wrong using other polk speakers for effects, it's less critical using the same speakers for highs. It is recommended, but alright.
When you have a 9.1 receiver, there will be output terminals for extra speakers.2Ch Tube Audio Convert -
Thanks.
