Hookup of RTi4 and RM87
fslsf
fslsf Posts: 2
I have an RX-V867 with Polk Audio RM87 speakers and PSW111. I also have a couple of RTi4 speakers. I was thinking of adding the RTi4 as High fronts surrounds for the same room.
Question: Is it possible to add the the vintages RTi4 and RM87 to have 9.1 speakers setup in the same room.
If yes! Can you tell me the setup (wiring) for the RTi4 to RM87?
  • aboroth00
    aboroth00 Posts: 1,108
    edited December 2010
    I believe your yammy is only capable of 7.1 and you need at least a 9.1 receiver of being able to setup 9.1 in your room
    2Ch Tube Audio Convert
  • aboroth00
    With that said, there is nothing wrong using other polk speakers for effects, it's less critical using the same speakers for highs. It is recommended, but alright.
    When you have a 9.1 receiver, there will be output terminals for extra speakers.
  • fslsf
    fslsf Posts: 2
    Thanks.
