ground loop problem
  • aboroth00
    aboroth00 Posts: 1,106
    edited December 2010
    disneyjoe7 wrote: »
    If using a power conditioner I would roll some equipment plugs to help with hum. I use a Monster 5100 which uses an isolation transformers to isolated ac outlets, I assume to reduce any hum / noise problems.
    A ground loop will not be cured or even affected by an isolated transformers. All the 5100 claims to do is to reduce hum from RF or radio frequency hums. A different in potentials of grounds causes a hum. Companies generally choose an arbitrary voltage in which to ground their equipment an a difference in voltage may cause a ground loop hum.
    2Ch Tube Audio Convert
  • aboroth00
    nap wrote: »
    Don't mean to hijack this thread but...
    I used these cheater plugs to stop the ground loop interference in my system. My two amps are both on the cheater plugs to stop this hum.
    Tell me I didnt waste hundreds and hundreds of dollars on AQ PC's and AQ king cobra IC's to have to rely on a cheap 2 dollar part? :confused: :mad:
    I am using the Panamax 5100 to condition the incoming ac. I have ea. amp powered by AQ pc's. BUT! on my source/avr (pre) I am also using a AQ pc that is 3 prong too, but the avr has only a 2 prong input.
    Q: perhaps on the pre I should roll the AQ pc with the stock pc to see if that works? Just thought of that while typing.
    But those dang cheater's work now :mad:
    thanks for reading,
    Matt :biggrin:
    There are several things you can do to avoid using an isolation transformer. I've gone through this and it's very annoying. Try to plug everything into the same outlet. Then if you do, please do not use a cheater plug they are dangerous and only meant to be a temporary fix. Try to trace where the hum is coming from, whether ti's your CATV or a simple RCA connection to your TV.
    My ground loop was a result from a RCA out from the receiver to the TV, I didn't even need.
    If these do not solve your woes try Jensen transformers, their parts are rated unlike other chinese parts to keep a faithful signal. Here's a link: http://www.jensen-transformers.com/.
  • aboroth00
    aboroth00 wrote: »
    If you have any questions give me a PM, i know some other cheap alternatives in case your hum from your CATV.
  • aboroth00
    disneyjoe7 wrote: »
    Sometimes power conditioners increase hum such as passing your CATV through the "Filter" which adds a voltage to the line.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    Good point thanks.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • Ethancf
    Ethancf Posts: 478
    I had hum in my old house. Used cheater plugs. Moved to new house with same equipment and cable connections without cheater plugs. No hum.
    New house solved the problem. :)
    THE SYSTEM
    Polk Audio LSiM 707 Mains
    Polk LSiM 702 f/x Surrounds
    Polk Audio LSiM 706 C Center
    SVS SB-17 Ultra Subwoofer
    Rotel RSP-1582 Pre/Pro
    Rotel RMB 1585 Amplifier
    Oppo UDP-205 Blu-ray Player
    Samsung PN64D550 64" Plasma
  • disneyjoe7
    Or old house with new wiring works too I'm sure.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • aboroth00
    Ethancf wrote: »
    Often times older houses use multiple grounds. Of course multiple grounds can cause problems such as your cable man grounding somewhere else other than where the rest of the house is grounded. Newer houses tend not to have this problem.
  • aboroth00
    disneyjoe7 wrote: »
    It's not necessary newer wiring, but how the house is grounded.
  • disneyjoe7
    Agreed but if I was going through the trouble to rewire grounds, I think its best to start over.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • aboroth00
    disneyjoe7 wrote: »
    Only a certified electrician to do that. With that said redoing the wiring in any home is going to be an expensive ordeal.
  • disneyjoe7
    Agreed.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • TrashyTrucker
    TrashyTrucker Posts: 225
    Question:
    My house ground is good....but...
    Would it be safe to ground the Satellite to house ground? Ive done research that a hum can persist if two units are following seperate grounds. hence the satellite is grounded seperately.
    I asked my electrician friend and he thinks I am ****! Of course he isnt into high end audio equipment. Ive presently placed two cheaters on my biamped Haflers on my fronts. I have tried everything except move the ground on the satellite. And or roll my Ic's. They are new Ic's from AQ, but that doesnt mean something is defective.
    Matt
    Integra DTR 50.2 used as a preamp
    Rotel RCD 1520 cdp
    AudioQuest Jaguar 72v dbs ic's
    AudioQuest type 8 wire
    biamped to:
    2-Hafler 9500 trans nova's
    AudioQuest NRG-3 power cable's
    dedicated AC line for
    Tesla Plex 20a duplex receptacle
    Panamax Max 7500 pro surge/line conditioner
    SDA SRS 3.1 TL's modded...
    spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
    Panasonic Viera G20 50" plasma
    ...SDA's are just like candy for your ears...
  • jinjuku
    jinjuku Posts: 1,523
    aboroth00 wrote: »
    Have to disagree with you there. An isolation transformer between two pieces of equipment on two different circuits prevents equipment from having an alternate path to ground.
    Check out this RANE Engineering note.
  • TrashyTrucker
    jinjuku wrote: »
    Thanks for the read Jinjuku:
    I tried and found some success with tying the two amps together with some external chassis ground strap. I then ran a strap from between them to the AVR (pre).
    Wow this experiment greatly reduced the volume of the noise! It may not have totally elliminated it altogether, but it is a start. I plan to run additional straps to ty into other componets and check back with you all with any new results. I am well pleased with this progress. ( I am not a fan of lifting the grounds permanently with cheaters. )
    thanks for reading,
    Matt :biggrin:
    Rotel RCD 1520 cdp
    biamped to:
  • aboroth00
    jinjuku wrote: »
    Using a power conditioner in my experience has the potential to make it better and make it worse, but no power conditioner I have used has solved a ground loop hum.
    Using something like a isolation transformer from Jensen transformer does work well.
  • aboroth00
    thanks for reading,
    Matt :biggrin:
    Yeap that does seem to work well. I heard some people had some success by connecting all their equipment with metal chassis with speaker wire so they sort of share the same ground. There's a piece of equipment to help with this but I forgot the name of it. Hopefully I can come up with it
    I would try to trace where the hum is coming from. it's probably a result from an unbalanced connection. And using as Jinjuku suggested a isolation transformer is a good method also. However, they are expensive. I would suggest that you avoid investing in a power conditioner until you try other methods first. Also try and use digital connections wherever you can.
