Subwoofer amp?
myke
myke Posts: 138
So I know older passive subs like svs need amps to power them (and crossover) but does a new Polk DSW Pro 600 benefit from one? Whats the skinny on sub amps?:confused:
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
Post edited by myke on
    edited December 2010
    What do you mean "what's the skinny?" Subs that are passive, give you some flexability by adding a seperate amp. Subs with built in amps don't, unless you want to rip them apart. You can't add an amp to an already built in amp on a sub.
  • aboroth00
    aboroth00 Posts: 1,106
    myke wrote: »
    The DSW Pro 600 does not need an external amp or an external crossover so it will not benefit from another sub amp or crossover.
    2Ch Tube Audio Convert
  • aboroth00
    tonyb wrote: »
    Some subs which are passive such as Hsu's cylinder subs need an external eq to produce a flat freq response. Other subs such as the SVS line and other passive subs may not external eq and you can interchange amps. It's usually not advisable to rip apart sub amps as they are usually designed to go well together, and more power may not necessarily help.
