Phantom center for HT?
madmax
madmax Posts: 12,434
edited December 2010 in Electronics
Is a phantom center better or worse than a downsized dedicated center? What would I hear differently?
Vinyl, the final frontier...
Post edited by madmax on
  • Conradicles
    Conradicles Posts: 6,372
    If you sit in the sweet spot you will be fine...but of axis listeners will suffer. That is what I have found on my brief journey.
  • kawizx9r
    kawizx9r Posts: 5,150
    Worked great for some movies when I used a 'phantom' center with my SDA 1-C's. I swore I had a center channel, but sometimes the voices can be a bit overwhelmed because the stereo speakers are playing just that...a stereo track which will include explosions/front left+right surround effects.
    Some AVR's even have settings to help you create that Phantom center. All depends what you've got IMO.
    Personally? I'd just go with a center channel...preferably amplified externally.
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
    treitz3 Posts: 20,076
    Things may have changed since I was into HT but I will say this. It is nothing more than a gimmick that adds processing, loses bass/mid-bass output and offers a false sense of the scene. It has it's attributes but in the whole scheme of things, it's a waste....IMO.
    I run without one, can't really say it bothers me either. But your choice is to do without or run a weak center. Try it both ways, you may have to run that center hotter if it's not up to par with the rest of the front stage.
  • bobman1235
    bobman1235 Posts: 10,822
    treitz3 wrote: »
    Are you saying Phantom centers are a gimmick? Or that center channels are a gimmick?
  • Face
    Face Posts: 14,340
    With speakers that image well, a phantom can sound good. But a timber matched center will sound better.
  • leroyjr1
    leroyjr1 Posts: 8,785
    Nothing like a dedicated center. The phantom doesn't compare, its a night and day difference.
  • JimMueller
    JimMueller Posts: 100
    Ideally I want the dialog to come from the center of the screen, but my center sits below the screen due to physical restrictions. If I'm in the sweet spot, then phantom is preferable to me because the sound comes from the center of the screen instead of below the screen (which I find distracting). If I'm sitting outside the sweet spot, then I prefer to have the center channel enabled.
    [/BeginDream]
    It'd be nice if I could afford a projector & matching screen and be able to put a center directly behind an acoustically transparent projector screen.
    [/EndDream]
    Yamaha RX-2600 receiver, Nakamichi Dragon, Mitsubishi HS-U80 VCR, Pioneer DVL-90 LD Player, Sony BDP-S550 Blu-ray player, Sony CDP-X555ES CD player, Carver TFM-42, Carver AV-634, Panasonic TC-P54V10 plasma, BenQ W1070 PJ, Fisher MT-90 turntable, AKG-K340 headphones, Polk SDA-1C mains, CS-400i center, FX A4 surrounds, Rti A1 surround backs
    bobman1235 wrote: »
    My apologies for not being precise in my explanation. Phantom centers.
  • pearsall001
    pearsall001 Posts: 5,324
    The center anchors the entire front soundstage & locks in the dialogue where it should be & just can't be replaced with a phantom center. Sure you'll get passable sound but you're cutting yourself short on the overall sound the way it was intended to be delivered. Timbre matched across the front is the best way to go.
  • djperez81
    djperez81 Posts: 388
    very well put... i would go with a center channel for sure.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • inspiredsports
    inspiredsports Posts: 5,502
    JimMueller wrote: »
    [/BeginDream]
    [/EndDream]
    Or go over screen/under screen with 2 dedicated centers. You then need to locate the left and right tweeters on the horizontal line that intersects where the over/under speakers sound ouput centers vertically. When you get the geometry right, this is a superior option.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • John K.
    John K. Posts: 822
    Max, it can be better in some respects and worse in others. First, two advantages of a separate center speaker are that the center channel material is anchored in that center position for listeners off center and that the center channel output level can be increased independently of the level in the main speakers(since center channel dialog in some movies is mixed too low in relation to other sounds going on, boosting the center channel 3-4dB in those cases can help).
    Then, as to a "phantom" center, it should be kept in mind that we've listened to that for many years when we listen to 2-channel sources on two speakers. Vocalists, instrumentalists or other material intended to image near the center are about equal in level in the left and right speakers and naturally appear to be coming from the center for someone sitting close to the center. As the listener moves away from the center, that image moves out with him, but no farther than the speaker on that side. Even for multi-channel material with a separate center channel, no processing is involved other than simply sending that center material equally to the mains when the center speaker is set "none".
    One advantage of using the main speakers for this is that they're often simply better than the center speakers often used if the center isn't the same vertical speaker used for mains. This can give a better overall result other than the two advantages of the separate center speaker which were discussed above.
  • mantis
    mantis Posts: 17,557
    This is spot on. There is no reason to use a "downsized center" for any reason. If you don't have room for the correct matching center , make room. You are only hurting your experience.
    I hate Phantom center , it sucks ****. This is only if a center channel is out of the question.
    Dan
  • ViperZ
    ViperZ Posts: 2,046
    Dedicated center channel is a way to go... I am currently using "phantom center" with my HT, as the center channel speaker is packed, and even though my B&Ws have a great image, I still miss the center channel a lot. All dialogues come through that channel/speaker, so it's really important to have one.
    Btw, I'd try to get a matching center channel speaker. Maybe, put it on a separate angled center channel stand in front and dial-in the distance / level with AVR? That's what I did - my B&W CDM-CNT does not fit on the shelf (it's a huge / tall center).
    Regarding matching center: I used to have Polk RT1000p and Polk CS245 center. Everything was great and awesome, until I bought matching Polk CS400. The difference in the dialogue clarity was HUGE.
    Panasonic PT-AE4000U projector for movies
    Denon AVR-X3600H pre/pro
    B&W CDM1-SE fronts
    B&W CDM-CNT center
    B&W CDM1 rears on MoPADs
    DUAL NHT SubTwo subwoofers
    Oppo BDP-93 Blu-Ray player
    Belkin PF60 Power Center
    Sony XBR-X950G 55" 4K HDR Smart TV + PS3 in the living room
  • JimMueller
    I thought about doing that earlier this year. The front of the 1C's are 34" from the rear wall and I was trying to keep the center(s) the same distance. Didn't find a wall bracket which would allow the center to sit above the TV and extend that far. Plus, I like the ability of being able to walk between the equipment and the wall for re-wiring, etc... the bracket would be in the way for that convenience.
  • madmax
    Lots of good info here! I will have a couple sets of main speakers so I'll try a pair of those as a center. Previously I was assuming only a phantom.
    madmax
  • jayman_1975
    jayman_1975 Posts: 672
    I think it depends alot on the processor or receivers capability to do a phantom center. I have Monitor Audio GS 60's and the GS center channel. I cannot hear a difference at all when using the center channel or using phantom center, none whatsoever.
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • ben62670
    ben62670 Posts: 15,969
    I like my SDA's with no center. I get plenty of center stage with them. Having a center above or below throws things off IMHO.
    Ben
  • leroyjr1
    ben62670 wrote: »
    Still got the big boys?
  • Joe08867
    Joe08867 Posts: 3,919
    Tried a Phantom and went right back to a dedicated center. Dialog suffered way to much without it.
