Can You Use Banana Plugs with Pold Montor 60's?
Billy1941
I was all set to install banana plugs on my setup, but found that apparently my Monitor 60's will not accept banbana plugs. Just tie down on the posts.
I am right or wrong? Never used banana plugs before, but I would appreciate anyone letting me know what the "score" is. Thanks!
Post edited by Billy1941 on
You need to unscrew the caps all the way to remove the black and red cap pieces from the speaker. Then you can use banana clips (after putting the screws back on)"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
Yes, what he said.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Would this be the same for Monitor 50's????Neal M.
HK AVR 254
Front - Polk M50's
Center - Polk CS250-s
Surr - Klipsch KSB1.1
Sub - Polk PSW10
Blue Ray - PS3 -
