6 ohm speakers,
mrbofus
mrbofus Posts: 297
edited December 2010 in Speakers
Howdy,
the other day I was in a thrift store and saw some off brand bookself speakers which I need for my garage and noticed they were 6 ohm. I will be using an older technics receiver. Also there were some 4 ohms as well.
Is this a big deal with small speakers in a garage setting?
Or would the be OK to use?
Greg
Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Onkyo DX-C390 CD Changer
POLK RTI8 Mains--Cherry
the rest...in process...slowly!!
  • AudioGenics
    AudioGenics Posts: 2,567
    You could check the specifications of your technics receiver to verify
    It would be typically rated to work with speakers designed from 4 to 8 ohm impedance
    so a 4 or 6 ohm nominal rating would be fine.
    I hope they were POLK Audio Speakers !
  • mrbofus
    mrbofus Posts: 297
    Thanks,
    yes after checking my receiver it is rated 4-8 ohm I guess I was unaware of 6 ohm speakers.
    And no they were not POLKs, cheap looking sony I think.
    I was looking for just something to get me by for a little while...
    Sharp Aqous 40" LCD
    Onkyo TX SR-507 AVR
