6 ohm speakers,
Howdy,
the other day I was in a thrift store and saw some off brand bookself speakers which I need for my garage and noticed they were 6 ohm. I will be using an older technics receiver. Also there were some 4 ohms as well.
Is this a big deal with small speakers in a garage setting?
Or would the be OK to use?
Greg
Greg
Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
Onkyo DX-C390 CD Changer
POLK RTI8 Mains--Cherry
the rest...in process...slowly!!
Onkyo TX SR-507 AVR
You could check the specifications of your technics receiver to verify
It would be typically rated to work with speakers designed from 4 to 8 ohm impedance
so a 4 or 6 ohm nominal rating would be fine.
I hope they were POLK Audio Speakers ! -
Thanks,
yes after checking my receiver it is rated 4-8 ohm I guess I was unaware of 6 ohm speakers.
And no they were not POLKs, cheap looking sony I think.
I was looking for just something to get me by for a little while...Sharp Aqous 40" LCD
Onkyo TX SR-507 AVR
