Tweeter question
Justaguy_99
Justaguy_99 Posts: 24
edited December 2010 in Speakers
I have a set of RT2000is and a CS400i in my home theater setup. All three speakers use the same model tweeter, however the center channel tweeter appears to have a magnet attached to the back while the towers do not.
Does anybody know the reason for this? I can provide picks if it helps.
Thanks!
Steve
  • Face
    Face Posts: 14,340
    It's probably a bucking magnet for shielding purposes.
  • Justaguy_99
    Hmm, so if I was replacing this tweeter, would I want to remove that and attach it to the new one?
    Steve
  • Face
    Face Posts: 14,340
    Anomymouse is correct, as long as it's not mounted near a CRT you should be fine.
  • Justaguy_99
    Got it. DLP here, so I should be fine. Thank you for the tip guys. :smile:
    Steve
