Tweeter question
Justaguy_99
I have a set of RT2000is and a CS400i in my home theater setup. All three speakers use the same model tweeter, however the center channel tweeter appears to have a magnet attached to the back while the towers do not.
Does anybody know the reason for this? I can provide picks if it helps.
Thanks!
Steve
Thanks!
Steve
Post edited by Justaguy_99 on
It's probably a bucking magnet for shielding purposes."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Hmm, so if I was replacing this tweeter, would I want to remove that and attach it to the new one?
Steve -
Anomymouse is correct, as long as it's not mounted near a CRT you should be fine."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Got it. DLP here, so I should be fine. Thank you for the tip guys.
Steve
