Best De-solder?
Rev. Hayes
Zingo's thread got me thinking....
What's the best desoldering braid (or desoldering method)?
I've been using Radio Shack braid and it is awful.
Sounds good to me...
Pinch the braid with both hands, approx .25" from each other, push it back and forth also side to side, it spreads it out and increases the surface area, making it more effective. A hot iron really helps too.
As for other brands, MCM electronics has a good selection."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
I like a quality solder sucker. I tried the soldering iron with a built in bulb, but it just isn't as powerful as a true solder sucked.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
My best desoldering method is to heat it up and smack it on the table I'm working on. It drops off just fine and if I was working on something more than a loudspeaker xover, as in a space shuttle component, I might care about it more. I've never found desoldering braid or suckers necessary at all for xovers and in regards to brands, I doubt it makes a bit of difference in this case.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I hope you are wearing pants when using that method.My best desoldering method is to heat it up and smack it on the table I'm working on. It drops off just fine and if I was working on something more than a loudspeaker xover, as in a space shuttle component, I might care about it more. I've never found desoldering braid or suckers necessary at all and in regards to brands, I doubt it makes a bit of difference in this case."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
Ahhhhhh
Will do!Sounds good to me... -
Pants? Never.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
So I've seen the bulbs.....
Is this "sucker" a powered vacuum system?Sounds good to me... -
Nope....well I guess you could call it a mechanical vac, often spring loaded, thumb operated tube in the electronics versions I've used.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
What are you working on? How often do you plan on doing this type of work?Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I'm about to start my second x-over rebuild but I spend a LOT of time repairing patch cords and busted guitar electronics.Sounds good to me...
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=370-325
and what I use.
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=370-030
I used to like braid, but I grew out of it.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I bought the bulb type, but it just doesn't have the vacuum power of the spring loaded designs. Another handy thing about the http://www.parts-express.com/pe/show...number=370-030 is that you can just use your soldering iron taking a piece out and then put one in without switching tools.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Weller makes a real nice vacuum sucker. Needs to be kept clean for optimum performance. :cool:
Why you folks feel the need for that at all boggles me. Nerds.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Rev. Hayes wrote: »patch cords and busted guitar electronics.
Ever do any guitar tube amp modding?--Gary--
Any braid works fine and better than any sucker IMO._________________________________________________
The problem with braid is getting it into tight spots and wicking solder out of small holes.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Spread the braid as I described above and turn your iron up, works better than any solder sucker/desoldering iron I've used so far."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Especially when you want to lift up traces. :eek: :biggrin:Any braid works fine and better than any sucker IMO.~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~ -
Yes, unless your soldering skilss are top notch, stay away from itRev. Hayes wrote: »Zingo's thread got me thinking....
I agree, a quality solder sucker is the best for the job in most cases. Solder wick (braid is last resort)I like a quality solder sucker. I tried the soldering iron with a built in bulb, but it just isn't as powerful as a true solder sucked.
:eek:My best desoldering method is to heat it up and smack it on the table I'm working on. It drops off just fine and if I was working on something more than a loudspeaker xover, as in a space shuttle component, I might care about it more. I've never found desoldering braid or suckers necessary at all for xovers and in regards to brands, I doubt it makes a bit of difference in this case.
:eek:
Nope, he probably wears a mini skirt in order to complement is fine desoldering methodPants? Never.
Stay away from the bulb, useless...Rev. Hayes wrote: »So I've seen the bulbs.....
...and it works great :cool:Nope....well I guess you could call it a mechanical vac, often spring loaded, thumb operated tube in the electronics versions I've used....
Agreed :eek:Especially when you want to lift up traces. :eek: :biggrin:
I have been using this brand and specific model number for years with great success, never had to replace the pump as I buy the replacement tips (propably every year at the time since I was using daily in my repair shop). Easily dismantles, maintainable (slight lubrication of the O ring, easily remove excess solder and replacable tips). This should last you a life time and perform greatly. A smaller model also exist (I don't remember the model number...)
http://www.youtube.com/watch?v=WVsz2zzDJaw
http://www.edsyn.com/index.php?Mode=piw&pn=DS017
http://www.ldbepurchase.com/ds017.html
''Quality has better taste (i mean better performance)
'' DARE TO SOAR:
For large components (xover pcb and such) and "home" use (low volume of work), the Soldapullt and a nice soldering iron is the way to go. Lots of volume in one shot and will really suck (As TECHNOKID has suggested
). I really like these as I have used this style of thumper for years. The little ones just don't cut it. You can use the Sodapullt for smaller components as well, as long as the pcb is single sided or at max 2 sided. When you get into multilayer pcbs' you just can't fight with a manual solder sucker.
For smaller components and "home" use, the Aoyue line is worth it. Again this is for home or hobbyist use (low volume of work). Ya just have to keep them clean, very important. Before each use just make sure the filters are clean, and use the cleaning rod to clear the suction tube and let er rip tater!
http://sra-solder.com/product.php/6417/22
This is comparable to the Hakko desolder station witch is really good, but really for higher volumes of work, and the price is more expensive.
Once you lift a few traces fighting the removal process, you will love the power vacuum system. Practice on pcbs' that are parts cars, broken, or something that you will not be worried if you mess anything up.
Product prices and quality just go up from here. If you have lots of money the sky is the limit. For the money and for low volume use the Aoyue is good bang for the buck.
These are tools, and you have to have the right tool for the job.
Nothing beats slamming circuit boards on the bench to remove molten solder so it can go fly'n! :biggrin::rolleyes: -
The bulb and the mechanical plunger type work very well for larger components like leaded capacitors and resistors. I usually use the mechanical plunger type when there are globs of solder. If I want to clean things up more then I follow up with the braid.
My dad has a solder / de-solder station and it is great for higher density leaded components like IC's. For speaker work it is not necessary but if you have one, why not.
I must confess to using the whacking the board on the table method at times. The only problems are that you can't control where the pieces of solder are going to land and you may break something, Oh yeah and you should stay away form the Ethan Alan; your wife will ... lets just say it may impact the future of your hobby.Stan
Main 2ch:
HT:
Other stuff:
I use this desoldering pump
and this desolder wick
http://www.parts-express.com/pe/showdetl.cfm?Partnumber=341-556
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | Galion TS P75 Pre | Holo Audio Cyan 2 Dac | MIT Shotgun S1 | Puritan Audio PSM136 Pwr Condtioner & Classic PC's | Legend L600 | Roon Nucleus 1 w/LPS - Tubes add soul! -
There you go. Two cheap options to try from the same place. I have used that same solder sucker for 9 years no issues. I had to cut the tip just a little. At that price you can buy a whole new one for the price of a tip.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Thats my weapon of choice,I much prefer it to braid.audiobilly wrote: »the Soldapullt -
Ya know, one could reckon this debate with that of vinyl cleaning methods.:cool:
+1 on the Soldapullt.Yes, unless your soldering skilss are top notch, stay away from it
:eek:
:eek:
Agreed :eek:
''Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
I prefer a good spring loaded solder sucker and +1 to a good braid.
