Best De-solder?
Rev. Hayes
Rev. Hayes Posts: 475
edited December 2010 in DIY, Mods & Tweaks
Zingo's thread got me thinking....
What's the best desoldering braid (or desoldering method)?
I've been using Radio Shack braid and it is awful.
Sounds good to me...
Post edited by Rev. Hayes on
  • Face
    Face Posts: 14,340
    edited November 2010
    Pinch the braid with both hands, approx .25" from each other, push it back and forth also side to side, it spreads it out and increases the surface area, making it more effective. A hot iron really helps too.
    As for other brands, MCM electronics has a good selection.
  • ben62670
    ben62670 Posts: 15,969
    I like a quality solder sucker. I tried the soldering iron with a built in bulb, but it just isn't as powerful as a true solder sucked.
    Ben
  • dorokusai
    dorokusai Posts: 25,576
    My best desoldering method is to heat it up and smack it on the table I'm working on. It drops off just fine and if I was working on something more than a loudspeaker xover, as in a space shuttle component, I might care about it more. I've never found desoldering braid or suckers necessary at all for xovers and in regards to brands, I doubt it makes a bit of difference in this case.
  • Face
    Face Posts: 14,340
    dorokusai wrote: »
    My best desoldering method is to heat it up and smack it on the table I'm working on. It drops off just fine and if I was working on something more than a loudspeaker xover, as in a space shuttle component, I might care about it more. I've never found desoldering braid or suckers necessary at all and in regards to brands, I doubt it makes a bit of difference in this case.
    I hope you are wearing pants when using that method.
  • Rev. Hayes
    Face wrote: »
    Ahhhhhh
    Will do!
  • dorokusai
    Pants? Never.
  • Rev. Hayes
    ben62670 wrote: »
    So I've seen the bulbs.....
    Is this "sucker" a powered vacuum system?
  • dorokusai
    Nope....well I guess you could call it a mechanical vac, often spring loaded, thumb operated tube in the electronics versions I've used.
  • ben62670
    What are you working on? How often do you plan on doing this type of work?
    Ben
  • Rev. Hayes
    I'm about to start my second x-over rebuild but I spend a LOT of time repairing patch cords and busted guitar electronics.
  • ben62670
    Ben
  • george daniel
    george daniel Posts: 12,096
  • ben62670
    I bought the bulb type, but it just doesn't have the vacuum power of the spring loaded designs. Another handy thing about the http://www.parts-express.com/pe/show...number=370-030 is that you can just use your soldering iron taking a piece out and then put one in without switching tools.
    Ben
  • [Deleted User]
    [Deleted User] Posts: 1,223
    Weller makes a real nice vacuum sucker. Needs to be kept clean for optimum performance. :cool:
  • dorokusai
    Why you folks feel the need for that at all boggles me. Nerds.
  • halo71
    halo71 Posts: 4,638
    Rev. Hayes wrote: »
    Ever do any guitar tube amp modding?
    --Gary--
  • Ricardo
    Ricardo Posts: 10,634
    Any braid works fine and better than any sucker IMO.
    SOPA
  • ben62670
    The problem with braid is getting it into tight spots and wicking solder out of small holes.
    Ben
  • Face
    Face Posts: 14,340
    Spread the braid as I described above and turn your iron up, works better than any solder sucker/desoldering iron I've used so far.
    treitz3 Posts: 20,132
    Ricardo wrote: »
    Especially when you want to lift up traces. :eek: :biggrin:
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Rev. Hayes wrote: »
    Yes, unless your soldering skilss are top notch, stay away from it :wink:
    ben62670 wrote: »
    I agree, a quality solder sucker is the best for the job in most cases. Solder wick (braid is last resort)
    dorokusai wrote: »
    :eek::confused::eek::confused:
    Face wrote: »
    dorokusai wrote: »
    Pants? Never.
    Nope, he probably wears a mini skirt in order to complement is fine desoldering method :tongue::tongue::tongue:
    Rev. Hayes wrote: »
    Stay away from the bulb, useless...
    dorokusai wrote: »
    Nope....well I guess you could call it a mechanical vac, often spring loaded, thumb operated tube in the electronics versions I've used....
    ...and it works great :cool:
    treitz3 wrote: »
    Agreed :eek:
    I have been using this brand and specific model number for years with great success, never had to replace the pump as I buy the replacement tips (propably every year at the time since I was using daily in my repair shop). Easily dismantles, maintainable (slight lubrication of the O ring, easily remove excess solder and replacable tips). This should last you a life time and perform greatly. A smaller model also exist (I don't remember the model number...)
    http://www.youtube.com/watch?v=WVsz2zzDJaw
    http://www.edsyn.com/index.php?Mode=piw&pn=DS017
    http://www.ldbepurchase.com/ds017.html
    ''Quality has better taste (i mean better performance):wink:''
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • audiobilly
    audiobilly Posts: 351
    For large components (xover pcb and such) and "home" use (low volume of work), the Soldapullt and a nice soldering iron is the way to go. Lots of volume in one shot and will really suck (As TECHNOKID has suggested:smile:). I really like these as I have used this style of thumper for years. The little ones just don't cut it. You can use the Sodapullt for smaller components as well, as long as the pcb is single sided or at max 2 sided. When you get into multilayer pcbs' you just can't fight with a manual solder sucker.
    For smaller components and "home" use, the Aoyue line is worth it. Again this is for home or hobbyist use (low volume of work). Ya just have to keep them clean, very important. Before each use just make sure the filters are clean, and use the cleaning rod to clear the suction tube and let er rip tater!
    http://sra-solder.com/product.php/6417/22
    This is comparable to the Hakko desolder station witch is really good, but really for higher volumes of work, and the price is more expensive.
    Once you lift a few traces fighting the removal process, you will love the power vacuum system. Practice on pcbs' that are parts cars, broken, or something that you will not be worried if you mess anything up.
    Product prices and quality just go up from here. If you have lots of money the sky is the limit. For the money and for low volume use the Aoyue is good bang for the buck.
    These are tools, and you have to have the right tool for the job.
    Nothing beats slamming circuit boards on the bench to remove molten solder so it can go fly'n! :biggrin::rolleyes:
  • skrol
    skrol Posts: 3,466
    The bulb and the mechanical plunger type work very well for larger components like leaded capacitors and resistors. I usually use the mechanical plunger type when there are globs of solder. If I want to clean things up more then I follow up with the braid.
    My dad has a solder / de-solder station and it is great for higher density leaded components like IC's. For speaker work it is not necessary but if you have one, why not.
    I must confess to using the whacking the board on the table method at times. The only problems are that you can't control where the pieces of solder are going to land and you may break something, Oh yeah and you should stay away form the Ethan Alan; your wife will ... lets just say it may impact the future of your hobby.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    heiney9 Posts: 25,529
  • ben62670
    heiney9 wrote: »
    There you go. Two cheap options to try from the same place. I have used that same solder sucker for 9 years no issues. I had to cut the tip just a little. At that price you can buy a whole new one for the price of a tip.
    Ben
  • FTGV
    FTGV Posts: 3,650
    audiobilly wrote: »
    the Soldapullt
    Thats my weapon of choice,I much prefer it to braid.
  • audiobilly
    Ya know, one could reckon this debate with that of vinyl cleaning methods.:cool::confused:
  • helipilotdoug
    helipilotdoug Posts: 1,230
    +1 on the Soldapullt.
    TECHNOKID wrote: »
    Agreed :eek:
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • hearingimpared
    hearingimpared Posts: 21,136
    I prefer a good spring loaded solder sucker and +1 to a good braid.
