Specs ?
Pauly
150 watts per channel (8 ohms)
- 400 watts monobridged
- AB speaker switching
- Auto-On signal sensing circuit
- Left and right channel level controls
- Line output jacks
- Toroidal power supply
- >0.04% THD
- Stable into 2 ohm loads
- >110 dB S/N ratio, 2 dB headroom
- 3.5 x 16.5 x 13.25 in., 27 lbs.
What is the Toroidal PS?
- Line output jacks
- >0.04% THD
Life without music would♭
The Torroidal PS is probably the best you can get in a receiver, preamp, etc. It basically overcomes the shortcommings of standard power supply units by filtering out AC line interference and delivers better and cleaner power to components. I actually have one in my Panamax MAX5000 AC regenerator as well as my Integrated amp...the sound...dead silence without a hint of interference on the line. It's the way to go......See the Music, Feel the Music, Be the Music...
