Specs ?
Pauly
Pauly Posts: 4,519
edited January 2004 in Electronics
150 watts per channel (8 ohms)
- 400 watts monobridged
- AB speaker switching
- Auto-On signal sensing circuit
- Left and right channel level controls
- Line output jacks
- Toroidal power supply
- >0.04% THD
- Stable into 2 ohm loads
- >110 dB S/N ratio, 2 dB headroom
- 3.5 x 16.5 x 13.25 in., 27 lbs.
What is the Toroidal PS?
Life without music would♭
  • kureboy99
    kureboy99 Posts: 53
    edited January 2004
    The Torroidal PS is probably the best you can get in a receiver, preamp, etc. It basically overcomes the shortcommings of standard power supply units by filtering out AC line interference and delivers better and cleaner power to components. I actually have one in my Panamax MAX5000 AC regenerator as well as my Integrated amp...the sound...dead silence without a hint of interference on the line. It's the way to go...
    ...See the Music, Feel the Music, Be the Music...
  • Pauly
    Pauly Posts: 4,519
    edited January 2004
    Thx
