Wall mount of Monitor 40's AM40 mount
Swede_Deep
Fronts: Monitor 70's
Center: CS2
Rears: Monitor 40's
Sub: PSW505
Receiver: Onkyo TX-SR707
Panasonic DMP-BD65
Panasonic TC-P58S1
I have yet to mount the 40's, the way the room is built, they would have to be mounted pretty high up on the wall. Is there a limit to the recommended height?
Really don't want to put them on stands,kids in the area.
Center: CS2
Rears: Monitor 40's
Sub: PSW505
Panasonic DMP-BD65
Panasonic TC-P58S1
Swede_Deep wrote: »Fronts: Monitor 70's
Center: CS2
Rears: Monitor 40's
Sub: PSW505
Panasonic DMP-BD65
Panasonic TC-P58S1
I have mine mounted 6+ feet in the air with no problems. Recommend using AM40 Pinpoint Mounts from Amazon. Check out the link to my system showcase to see pics of how they look."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
That does look great! I have the AM40 Pinpoint Mounts. Them together with the 40's have been collecting dust since April. Well I think I'm off to mount them today then.
Thanks! -
Only suggestion I have is that I didnt use the included mounting screws to attach the speaker to the plate. I used industrial strength velco because I didnt want screw holes in the speaker. You could also maybe use blue tack as well."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
http://rothmans.smugmug.com/Other/SmugShots/smugshot6745825/1106593103_SxJRe-M.jpg
I put 3 screws trough the bottom. At least I know they will not fall on top of my nugget.
Still got to get around to pull some cable to them.
