Wall mount of Monitor 40's AM40 mount
Swede_Deep
Swede_Deep Posts: 23
Fronts: Monitor 70's
Center: CS2
Rears: Monitor 40's
Sub: PSW505
Receiver: Onkyo TX-SR707
Panasonic DMP-BD65
Panasonic TC-P58S1
I have yet to mount the 40's, the way the room is built, they would have to be mounted pretty high up on the wall. Is there a limit to the recommended height?
Really don't want to put them on stands,kids in the area.
    EndersShadow Posts: 17,765
    edited November 2010
    Swede_Deep wrote: »
    Center: CS2
    Rears: Monitor 40's
    Sub: PSW505
    Panasonic DMP-BD65
    Panasonic TC-P58S1
    I have mine mounted 6+ feet in the air with no problems. Recommend using AM40 Pinpoint Mounts from Amazon. Check out the link to my system showcase to see pics of how they look.
  • Swede_Deep
    That does look great! I have the AM40 Pinpoint Mounts. Them together with the 40's have been collecting dust since April. Well I think I'm off to mount them today then.
    Thanks!
    Only suggestion I have is that I didnt use the included mounting screws to attach the speaker to the plate. I used industrial strength velco because I didnt want screw holes in the speaker. You could also maybe use blue tack as well.
  • Swede_Deep
    http://rothmans.smugmug.com/Other/SmugShots/smugshot6745825/1106593103_SxJRe-M.jpg
    I put 3 screws trough the bottom. At least I know they will not fall on top of my nugget.
    Still got to get around to pull some cable to them. :)
  • Swede_Deep
