Bi-wiring monitor 70 series 2 makes painful sound
Drake5
Drake5 Posts: 15
edited November 2010 in Speakers
I haven't upgraded my receiver yet so bi-amping is not an option...yet. Tried bi-wiring and noticed clarity of upper and lower tones...The sound seemed to open up and separation of instruments was better. I really can identify where the cymbals for example were coming from.
However, similar to the tsi300 when bi-wired, the soundstage got deeper which made it somewhat painful and fatiguing to listen to (the same experience with the boston acoustics 226, w/c i returned).
Do you have similar experience when bi-amping the monitor 70s?
Thanks.
Post edited by Drake5 on
  • Polkersince85
    Polkersince85 Posts: 2,883
    You're not doing yourself, your 12yo JVC receiver or the speakers any good. You now have real speakers so you need real power to push them. The speakers are not your problem. They will sing with better amplification.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Drake5 wrote: »
    Thanks.
    Welcome to Club Polk Drake :smile:
    Bi-wiring is useless, unless you have separate amps which allows you to bi-amp, don't bother as you will cause your self more headaches than anything else. Simply use the speakers with the short on providing them with a single cable from a single O/P until you feel the nedd to upgrade your amplification.
    Cheers!
    TK
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • BlueFox
    BlueFox Posts: 15,250
    As has been pointed out, bi-wiring simply moves the jumper from the speaker to the amp.
    F1nut Posts: 51,925
    That's the first time I've heard that one.
  • jayman_1975
    jayman_1975 Posts: 672
    Isn't a deep soundstage a good thing?
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
    F1nut Posts: 51,925
    For most of us, yes.
  • Drake5
    Drake5 Posts: 15
    Thanks for the suggestions..I guess I'll just have to wait a little while and save my pennies to get an avr with pre-outs and external amps.
    About the deeper soundstage, yeah that is what I experienced, I really would have liked it that way but I could not stand the pressure even if the sound was cleaner..dunno maybe it's my old receiver.
    F1nut Posts: 51,925
    What you are expressing makes no sense. A deeper sound stage cannot result in pain and fatigue nor will it result in pressure.
    I want to say your hearing distortion, put the jumpers back on the speaker and just use one set of cables. Of coarse I'm assumeing you removed the jumpers to begin with when you bi-wired.
  • Drake5
    Drake5 Posts: 15
    Yes, I removed the jumpers. This is the same experience I had with the tsi 300s, sound was noticeably clearer and deeper but fatiguing. Even my wife had the same experience. I want back to single connection and the sound is smooth again.
  • Jetmaker737
    Jetmaker737 Posts: 1,123
    Your results are weird but at least for you it shows that biwiring does make a difference.
  • NeilGabriel
    NeilGabriel Posts: 1,487
    without adding your own crossover to bi-wiring, how can it have any effect?
    F1nut Posts: 51,925
    What bi-wiring does in effect is to get rid of the lousy jumpers that come with speakers. However, one can simply replace the stock jumpers with high quality wire and get the same benefit.
  • TECHNOKID
    Agreed, the only insignificant effect bi-wiring may have is longer distance for unwanted return effect from one driver to the other but for most in-home use people use pretty short cables anyway.
    DARE TO SOAR:
  • MLZ
    MLZ Posts: 214
    That assumes that the new speaker cables are of higher quality than the jumpers (which gets us into the debate of being able to hear differences in speaker cables - and a discussion I do not want to go to :eek:)
  • Drake5
    Drake5 Posts: 15
    Funny you mentioned about types of wires...i am not going to claim that i am an expert or even close to being average but i have had experience with quality headphones and i can perceive the difference in sound quality.
    i originally tried the cheapest monster cable against a radio shack 14 gauge and i did find the two sound different. the monster sounded cooler and the radioshack sounded warmer...coupled with my old receiver, i liked the radio shack's better. i can't justify better cables right now so i'm settling with these cheap cables for now.
  • jinjuku
    jinjuku Posts: 1,523
    Drake5 wrote: »
    :rolleyes:
