What in your path caused the biggest change?
VR3
VR3 Posts: 29,609
edited December 2010 in 2 Channel Audio
Hands down the biggest change I have heard at this point - in order is as follows...
1) Crossover upgrades - This literally transformed everything
2) MIT Shotgun Cables - Another immediate, positive difference
3) Keeping it simple.. No eqs, no crossovers, no extra things in the mix - CDP > PRE > Amp > Speakers
4) Having a good quality Source
5) Tube Preamp
Post edited by VR3 on
«13
  • Systems
    Systems Posts: 14,872
    edited November 2010
    Dedicated cryoed 10 ga 20 amp line, and Furutech 20amp gold recept.
    Testing
    Testing
    Testing
  • ben62670
    ben62670 Posts: 15,969
    It was a set of Polk drivers that I was using to replace some foam surround drivers with. I heard them and it was a gradual downhill slope from that till I got my SDA'2. It was all over after that.
    Ben
    Ben
  • doctor r
    doctor r Posts: 837
    Tubes
    Tubed CDP - Tubed Preamp - Tubed Poweramps.
    The VAC Standard LE pre made my system 4 levels better IMO.
    integrated w/DAC module Gryphon Diablo 300
    server Wolf Alpha 3SX
    phono pre Dynamic Sounds Associates Phono II
    turntable/tonearms Origin Live Sovereign Mk3 dual arm, Origin Live Enterprise Mk4, Origin Live Illustrious Mk3c
    cartridges Miyajima Madake, Ortofon Windfeld Ti, Ortofon
    speakers Rockport Mira II
    cables Synergistic Research Cables, Gryphon VPI XLR, Sablon 2020 USB
    rack Adona Eris 6dw
    ultrasonic cleaner Degritter
    treitz3 Posts: 20,185
    Depends on where I was in my audio journey as to what made the biggest change. Everything affects everything.
  • AudioGenics
    AudioGenics Posts: 2,567
    .....5) Tube Preamp
    It was the Audio Research SP-1 preamplifier.
    Made in the USA and made with great Respect
    to the High End Client.
  • zarrdoss
    zarrdoss Posts: 2,562
    Joining this forum.
    SCompRacer Posts: 9,137
    Acoustic treatments. Saves a bunch of floundering around. If the room has problems, you absolutely cannot get a totally accurate representation of the gear in the mix.
  • steveinaz
    steveinaz Posts: 19,546
    1. My speakers
    2. My DAC
    3. Passive linestage
    In that order...
    Toolfan66 Posts: 18,257
    zarrdoss wrote: »
    Joining this forum.
    I have to agree!!! lol:tongue:
    Crossover Upgrades W/RDO's
    Spikes!!! That was huge.
    Getting a dedicated Pre Amp!! Another huge step.
    MIT Shotgun Cables!!
    Tubes (Phono Pre, Pre Amp)
    Power Cords
    Room Treatments
    All of these made a huge impact and are in no paticular order.
    Can't forget the rings I made for the drivers and passives of my SDA's:cool:
    xcapri79 wrote: »
    100) Cables and Interconnects (The law of diminishing returns applies here)
    Can't help yourself can you??? This wasn't asked..
    Trolling at it's finest!!
  • falconcry72
    falconcry72 Posts: 3,580
    Discovering SDA's:smile:
    More serious power amp
    Source/External DAC
    Speaker placement
  • vmaxer
    vmaxer Posts: 5,121
    deleted...will re post
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • vmaxer
    vmaxer Posts: 5,121
    xcapri79 wrote: »
    1) Speakers
    2) Source
    3) Amplifier
    4) Preamp
    5) Room Treatments
    Some things never change huh:rolleyes:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • quadzilla
    quadzilla Posts: 1,543
    treitz3 wrote: »
    This. First big change was going from a low-end HK to a Pio Elite AVR. Then there was much mucking around without a lot of results until I went to external amplification. More mucking around until I switched to Anti-cables speaker cable in a bi-amp configuration, etc.
    The last really big change was just simply learning to properly set up my turntable and getting a really good tube phono stage. This one is a really good example because I thought I had my cart set up properly. It sounded fine on my old pre. But once I got the Aural Thrills, I could hear a lot of cart break up. Once I got really, really painstaking in my cart set up, they started working together to provide some truly amazing sound.
    So there isn't one thing that I can point to and say "that's the change that made all the difference, or even the biggest difference."
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • hearingimpared
    hearingimpared Posts: 21,136
    Power Cords
    Room Treatments
    Mine is close Larry;
    1) Musical Fidelity Tri-Vista 300
    2) xover upgrades & RDO198s
    3) MIT Shotgun S3s ICs all around
    4) Raysonic CD 168 (closest thing to analog in CDP I've ever heard)
    5) ZYX Airy 3 Cartridge.
    If I had to pick just one it would be a tie between the xover upgrades and the Tri-Vista.
  • zingo
    zingo Posts: 11,258
    The Shuguang Treasure 300B integrated amp was the biggest and best change to my system.
  • ShinAce
    ShinAce Posts: 1,194
    1) speakers
    2) room treatments
    3) alcohol
    That is all.
  • Ern Dog
    Ern Dog Posts: 2,237
    I'd have to say Modwright tube preamp made the biggest difference.
  • Jetmaker737
    Jetmaker737 Posts: 1,138
    My LSi-15's. Since then the rest of the system has had to change to measure up.
    Ern Dog wrote: »
    I hear ya brother.... I love mine!
  • vmaxer
    vmaxer Posts: 5,121
    Several years ago I purchased a new pair of RT55i's and found this forum...It started there.
    By reading more and more on here I went from just having a basic Onkyo receiver and the 55's to what you see in my signature.....A lot of Polk and other stuff.
    I realize that my system is still not a top end system, but I will keep upgrading as I can and maybe some day I will have one.
    So, joining this place would be the biggest difference:biggrin:, since I wouldn't have know what I was missing. Now just missing a lot of money:redface:
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    Sunfire CG 200 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • WilliamM2
    WilliamM2 Posts: 4,808
    Speakers and placement have made the biggest difference. Anything else has always been subtle at best.
  • madmax
    madmax Posts: 12,434
    Tubes, horns and vinyl.
    Vinyl, the final frontier...
  • NJPOLKER
    NJPOLKER Posts: 3,475
    zarrdoss wrote: »
    Joining this forum.
    I agree 100% or so :redface: It has also cost me plenty but well worth it :smile:
    When I upgraded the x-overs in my three pair of Polks I gotta say they were the most effective and economically wise decisions I ever made.
    Buying 2 Mullard and 2 Mazda tubes for the Anthem PRE2L for about $100. each made a huge difference in sound quality. Not an inexpensive upgrade but well worth it. The music blossomed and became realistic, no B.S. it transformed the entire scope of my listening pleasure. As someone around here says "tubes rule".
    Upgrading the caps in my Anthem PRE2L was a great move for the dollar spent. For $50.00 you can't beat it and it was a easy DIY upgrade. I have a thread around here explaining the upgrade process I think.
  • W WALDECKER
    W WALDECKER Posts: 900
    #1 Dropping transistors in favor of tubes #2 trying many different components in my system and listening room to help me discern what my preferences really are.
    Rogue Audio stereo 100 tube amplifier - Lector Zoe preamplifier with 6H30 pi's
    .Audience AU24SE speaker and ic cables- Chord Qutest DAC - Black Cat Silverstar II 75ohm digital cable-Tyler Acoustics Linbrook Signature system with large bass cabinets to accommodate 10" Seas magnesium woofers.2xhmpsuownoj.jpg
  • lmuller1
    lmuller1 Posts: 16
    Speakers and placements I would put at the top of the list. I would say source material is huge. Can't stand poorly recorded music or over-eq'd stuff. I find most live recordings hard to listen to. Thank goodness there are many exceptions to this.
    Power for big headroom. dbx bx-3 mk2 400/ch, dbx bx-2 250/ch, QSC 1400 300/ch and QSC CX-702 700/ch. Makes for effortless control. I'll take too much power over not enough any day. When I went from a QSC model 1400 at to the CX-702 on my dbx sf1's and was stunned at the difference.
  • zingo
    zingo Posts: 11,258
    lmuller1 wrote: »
    Agreed. Most non-audiophiles have no idea how much of a difference this makes.
  • ben62670
    People telling me to use great top dollar shelf stuff when I could mod middle of the road stuff to kick butt.
    Ben
  • jinjuku
    jinjuku Posts: 1,523
    1> Speakers
    2> Clean and abundant wall power
    3> Ample amp power
    I have a feeling when I get around to it: Dumping passive x-over components and going fully active with enough channels of amplification. Which will have the side benefit of about 30% more power getting to the driver instead of warming resistors on a passive x-over. A 2 for 1 type upgrade.
  • BottomFeeder
    BottomFeeder Posts: 1,684
    Moving from a, gulp, receiver, to an NAD integrated.
    "Wish I didn't know now what I didn't know then." Bob Seger
  • 98Badger
    98Badger Posts: 317
    1. Speakers without a doubt
    2. Well recorded material
    3. Plenty of power
    4. Quality sub
    5. Good DAC
