to bi wire
leftwinger57
HY Guys,
It's been a while since last visited and since my 2- ch gear is growing I'd
like to inprove on my speakers. I'm kinda leaning towards vintage Klipsch
but it's not my only choice. What I have heard is to bi wire speakers.1st
question is why and 2nd is there any real advantage. Now tell me if I'm wrong but it seems that a jumper goes from one speaker to the other then only one set to the amp. Can this be right.Again not sure so let me know
H/T
Toshiba au37
Yamaha rx-v665 avr
Denon 1940 cdp
Klipsch 500 w/ 8insub
Yamaha ysd-11 dock
Apple i-pod
2-channel
Adcom gfa555 200wpc
Onkyo p-301 pre
Infinity sm112s
Denon 1940 cdp
Shure-pro headphones
H/T
Toshiba au37
Yamaha rx-v665 avr
Denon 1940 cdp
Yamaha ysd-11 dock
Apple i-pod
2-channel
Adcom gfa555 200wpc
Onkyo p-301 pre
Infinity sm112s
Denon 1940 cdp
Please do a search on the forum, this topic has been beat to death so many times.
Biwiring is running two sets of cable to EACH speaker, one for the high, one for the low, and removing the jumper block on the back of the speaker terminals.
You will probably not even see a difference....but yes, please search.Main Surround -
Den - Rotel RSP-1068 / Threshold CAS-2 / Boston VR-M60 / BDP-05FD -
Don't bother with the BiWiring. Get one set of good cables.
Ben -
To the OP, while you're at it, might as well do a search on the associated topic of biamping, and the meaning of passive and active biamping... another topic that has been butchered fairly well enough...Fronts: Wharfedale diamond 9.6
Sub: Wharfedale sw250
Rears: Wharfedale diamond 9.1
Center: Paradigm cc-350
Pre-amp: Oppo dv981hd
Amp for fronts: Parasound hca-1500a
Amp for rears: Adcom gfa-5400
Amp for center: Marantz MA500 monoblock
Polk multimedia speakers for PC setup -
Experiment a must..I have done Bi-Wiring which improve sound 10-15%leftwinger57 wrote: »HY Guys,
H/T
Toshiba au37
Yamaha rx-v665 avr
Denon 1940 cdp
Yamaha ysd-11 dock
Apple i-pod
2-channel
Adcom gfa555 200wpc
Onkyo p-301 pre
Infinity sm112s
Denon 1940 cdp
but then that just me,everybody have different opinion so experiment first..TV :>Panasonic TC-P55VT50
RECEIVER :> HARMAN KARDON AVR 7300
FRONT :> L & R :> POLK RTI A9 500 W
AMP :1> PARASOUND HALO A21 250 W
AMP :2> EMOTIVA UPA-1 200 W
CENTER :> POLK LSiM 706c 250 W
SURROUND SIDE :> POLK RTi A3 150 W
SURROUND REAR :>POLK FXI A6 150 W
DVD PLAYER(HD) :>TOSHIBA HD X-A2
DVD PLAYER(BLU-RAY) :>Panasonic DMP-UB900
POWER CONDITIONER :> PANAMAX M5400-EX
SUBWOOFER :A> SVS SB16-Ultra 1500 W Front
SUBWOOFER :B> SVS SB16-Ultra 1500 W Rear -
You will see a difference; two pair of wires versus one pair. However, you will not hear a difference. :biggrin:Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Personally, I think it depends more on the speaker design. For instance, I have a pair of TSI400 speakers, they have one tweeter and three woofers. When bi-amping, the tweeter gets power from one channel and the woofers get power from the other. The TSI series would have virtually no benefit AT ALL from bi-amping.
Now a speaker that has a tweeter, midrange, and woofer, MIGHT be different. In this case the one channel would feed the tweeter and midrange, while the second channel would feed the woofers. I do not have speakers to even test this. So I can't say there would be a benefit or not, but this type of separation would lend itself to bi-amping much more so than the TSI series of speaker.
Now this might also depend on how you feed the bi-amped speaker. If sending power from a receiver, then you may very well not see any benefit either because (from what I hear) the power is shared. Now if you use an external amp, which has it's own dedicated power for each channel; again you MIGHT see a benefit. But not from the TSI series of speaker of course. I wonder, if in this case you would over power the TSI tweeter.
Good luck with this though. Other people would know much more about this than I would. But I think clarity can not come from one's opinions, but from testing for each speaker, receiver or amp combination. Unfortunately, too many people have opinions and no hard facts. I can only tell you what the TSI 400 does, and assume for the TSI 500 because it only has a tweeter and woofer design the same as the TSI 400. My results are the same as others, no real benefit; but then I don't have a separate amp and a speaker design that lends itself to bi-amping.
I wonder if someone with RTi A7 or A9 (not the A5) or LSi15 or LSi25 speakers can test with an external amp for bi-amping? This might tell us how the power is handled and if there is any benefit.Main Home Theater
Receiver: Onkyo TX-NR1008
Fronts: TSI400 (bi-amp)
Rears: TSI200
Center: CS20
Sub: Cerwin-Vega CX12S
Monitor: Samsung UN55C6300 LED -
I bi-wire because it's possible. Have I heard a noticeable difference in any of the hundred speakers I've had pass thru my home? Nope.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Yup, same here. I have bi-wire cables so I use them. If I had singles, I'd make good jumpers and be done, which is how I run my fronts in my HT setup.-Kevin
2 Channel:
Oppo BDP-83 SE
Squeezebox Touch
Muscial Fidelity M1 DAC
VTL 2.5
McIntosh 2205 (refurbed)
B&W 801's
Transparent IC's -
I notice that PinkTulip7 is the only one I see so far that has the setup I am talking about; RTi A9 on a separate amp. I also notice he mentions a 10-15% benefit.
Now looking at vc69, using a TX-SR606 and LS 90's, it is unlikely he would see any benefit because of the receiver being used. Now if he switched to a TX-NR708 and an external amp, he might hear a difference.
As for dorokusai, who knows what he has so it is hard to comment. No offense intended.
Again, I think it has more to do with equipment configuration than saying yes it has a benefit or no benefit.
Maybe using two different amps to power the speaker, a low powered amp for the tweeter and midrange, combined with a high powered amp for the sub/woofer side of the speaker. Benefits can only be quantified by testing specific setups.
Now is there a thread that specifically talks about the EQUIPMENT being used for the bi-amping. If so, please direct me there. I would love to see what equipment people use to bi-amp.
For example, I might change my setup to include an external 5 channel amp. I'll keep the back surrounds, front high, front wide, and front tweeters and such on the receiver, and use the external 5 channel amp for the fronts (woofers), center, surround. Hmmm sounds like an interesting bi-amping test; AND I could even do this with my TSI400.Main Home Theater
Rears: TSI200
Center: CS20
No offense at all. My rig changes so much that listing my gear would be silly. I have only one thing that will never change and has powered every rig since 2003....been at Polkfests'...and at other larger audio events....my CTC amplifier.
I'm also a MIT cables fan so that's usually a given but otherwise I'll try anything that might sound good....should sound good....has never sounded good....etc etc.
You should try and listen to everything possible, regardless of popular opinion. Sure, take all that into account but in the end, decide for yourself. Don't sweat what others sayCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
Well saiddesign is where science and art break even. -
You can also find cables that are specifically made for bi-wiring so that can help cut down on clutter. Mybe I'm oversimplifying this but it appears to me that removing the bridge and bi-wiring only moves the bridge (or jumper) point closer to the amp. I bought Bi-wire cables on accident once and thought i'd try them out while they were there. I couldn't hear any difference at all. Then again I may not have the most refined ears, and so I agree with doro that you should check it out for yourself and see what you think. the worst that can happen is that youll be out the money of another set of cables.design is where science and art break even.
Well said
I love that statement. Awesome BF :biggrin:
If you don't try out things why bother being here? This hobby is all about doing new things and that's what you should do, regardless of what the collective say. I've personaly been able tp experience all kinds of stuff minus popular opinion, that I simply took a chance on or was led by the minority. You'll get great advise here but also go with your gut. You'll lose, you'll win, who cares...you'll learn.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
As Mark Twain was credited to say, "A man who carries a cat by the tail learns something he could learn in no other way."
:biggrin:design is where science and art break even.
