Hooking up to speakers to the same channel
rogerd
rogerd Posts: 63
Hi,
For my back speakers I hooked up two sets of M10 they are stacked on top of each other ( I had an extra set I'm thinking that I can point then in opposites directions for hopefully a better surround sound effect I had seen a set triangle shaped polks at Future shop so that's where I got the idea) my AVR is a HC 1600 50 watts per channel will this work?
Thanks in advance for any comments.
  • AudioGenics
    AudioGenics Posts: 2,567
    edited November 2010
    be aware of your resulting impedance / resistance
    remember Ohm's Law will be in effect
  • nguyendot
    nguyendot Posts: 3,596
    Will it work? Yes. Is it a good idea? probably not.
    You probably have them hooked in parallel, resulting in a 4 ohms nominal impedance. You may slowly kill your receiver if you watch stuff with a lot of surround material. I'd just use one set, or get a 7.1 receiver so you can do a true surround and surround back setup.
    Main Surround -
  • thuffman03
    thuffman03 Posts: 1,325
    Welcome to the forum!
    I see no added value to doing this.
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • Face
    Face Posts: 14,340
    Bad idea.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    Welcome to Club Polk rogerd :smile:
    I agree with the above posters that you do not have anything to gain and everything to loose by doing this unless your AVR has pre-outs and you intend to use seperate amps or some form of interface to achieve this otherwise, you could damage either the AVR or speakers not counting that the SQ will more likely be crap.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • rogerd
    rogerd Posts: 63
    Well thanks for the info folks,
