Faston connectors for drivers
Outfitter03
Outfitter03 Posts: 563
edited November 2010 in DIY, Mods & Tweaks
Does anyone have a link for copper female Faston connectors? The only ones I have found are about $1.50 a piece and require buying a bag of 50. Probably wouldn't use all those in this lifetime.
If not, is there a brand of the tinned brass that you would recommend?
OR
Is it better to solder the chassis wire to the driver directly? This would be a PITA to remove later but have read some do this. Thanks for the help.
Post edited by Outfitter03 on
