Faston connectors for drivers
Outfitter03
Does anyone have a link for copper female Faston connectors? The only ones I have found are about $1.50 a piece and require buying a bag of 50. Probably wouldn't use all those in this lifetime.
If not, is there a brand of the tinned brass that you would recommend?
OR
Is it better to solder the chassis wire to the driver directly? This would be a PITA to remove later but have read some do this. Thanks for the help.
OR
PartsexpressPlease. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Unplated copper oxidizes and oxidized copper does not conduct very well. Get the tinned type. -
Outfitter03 wrote: »
That's What I use. They work well.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
Madison has a gold plated version."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the help!
how many and what size do you need ?
