Bi-Wire Jumpers vs. Plates included w/my speakers- Some insight please.
myke
What are the best in a moderate price point? Audioquest offers jumper copper and silver...any real difference? I've ordered banana plugs so since I will be using those soon does that make a difference? Are the plates that came with my speakers enough?
Bonus Room:
Pioneer Elite VSX-32
RTi A7's / CSi A6
DSW PRO 600 sub
Emotiva XPA-5 & Interconnects
Sony Surrounds (rears) - replacing soon
Samsung BD-C5500
Panamax M5300, Xbox360, ...& more coming
Living Room:
Samsung 58" PLasma
Monoprice in-ceiling speakers
old sony receiver (replacing soon)
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
Anything is better than those plates. Just keep it cheap to modestly priced....heck just DIY it and go crazy.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Just curious why the plates are considered to be so poor? They are very wide, flat pieces of metal that make great contact with the binding posts. Not sure what gauge they are equal to but probably at least 16?
Is the metal composition the issue?No earth robot is going to tell ME which button to press!!
--Stuff--
Front: Polk Audio RTi12
Center: Polk Audio CSi5
Surrounds: Polk Audio RTi8 (x4)
Sub: SVS PB10-ISD (Dual)
AVR: Denon AVR-3805
Blu-Ray: Panasonic BD30
Display: Sony KDL-55NX720B
STB: Xfinity X1DVR -
Nothing wrong with the plates. There are traces on the crossover that are much thinner than the jumper plates, and they aren't even gold palted!:eek: -
The problem is the capacitance of the plates, and also the core material. Not all frequencies ride on the surface where it is gold
Ben -
I'm not sold at that idea Ben but it's a cheap enough tweak that who cares either way...really, you can make your own for $20. You know what I mean?CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
sorry to sound stupid but just to be sure, would I run my normal speaker wire with banana plugs into the bottom inputs and just simply add a short strip of speaker wire into those same banana plugs (w/the speaker wire already in them) and connect them into the upper inputs?Bonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
old sony receiver (replacing soon) -
Myke,
Yes you could do that. But to simplify things, use good wire and run the jumpers like the stock jumpers. And then use your plugs. IMHO
Matt :biggrin:Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
Take some left over speaker wire, cut some short, just enough to make it to the top and bottom posts on the back of the speaker. Remove the plates, connect the speaker wire jumper and screw down the post cap. Now connect your speaker cables with the banana ends to the bottom post, they'll just push right in, walla, your done.HT SYSTEM-
lsi 9's -
trashy and tony,
thanks for dumbing it down for me, i really appreciate it. I though it would work something like that but you never know. I saw someones pictures posted here a while ago that looked like the description i mentioned earlier so thats what i was going off of in my head.Bonus Room:
RTi A7's / CSi A6
DSW PRO 600 sub
Samsung BD-C5500
Living Room:
Samsung 58" PLasma
I've heard the DH Labs Q10 jumpers are good with their silver over copper design and 10g conductors.
