Outlaw M2200 mono amp
orrb_05
orrb_05 Posts: 215
edited November 2010 in Electronics
OK - didn't get much response for opinions on the Yamaha MX-1 vs Anthem MCA 20, so I'm fishing for thoughts on the Outlaw in pair to power my mains (RTi12s).
AVR is a Yamaha RX-Z7.
Post edited by orrb_05 on
  • Sherardp
    Sherardp Posts: 8,038
    I started with the 2200's. Very nice amps, they run fairly cool to touch. And with 200 wpc they can run the RTi12s no problem.
  • pearsall001
    pearsall001 Posts: 5,373
    Nice amp, I had one powering my center before I picked up a Rotel RMB-1095 multi-channel amp. It did a great job...nice compact size too so you can actually stack them without any issues. Give them a try, for the money I doubt you'll be dissapointed.
  • TG Meat
    TG Meat Posts: 159
    ^^^^^ I think so too. Nicely price and solid performance. The only problem for me would be too many power cords, if you were to use more than two.
    Anthem D2v
    NAD M50 Music Server
    B & K Reference 200.5
    Parasound A21
    B & W 804 (Mains)
    B & W HTM1 (Center)
    Polk Rti4 (Surrounds)
    PS3
    Seaton Submersive HP
    Pioneer PDP 6010FD Kuro
    heiney9 Posts: 25,612
    The Anthem is head and shoulders a nicer amp than either the Outlaw or Yamaha. Not even worth questioning. Outlaw is solid gear but not the last word in musicality. On par with Emotiva but nicer and less forward.
    Good luck
  • praedet
    praedet Posts: 314
    How about ATi vs Anthem?
    HT: Ninja Master LSi9s, Ninja Master LSiC, Slightly Modded LSiFXs, Modded LSi7s, Outlaw LFM-1 EX and Polk PSW125
    Outlaw 970 Preamp, Outlaw 7700 Amp, Velodyne SMS-1, Oppo BDP-83,
    2 APC H-15s and a Panamax 5400 for good measure ;)
    Stereo: DIY Alix Music Server, DODD Audio Battery Tube Buffer, Modded DAC-60 and MF V-Link (for now), DIY Silver ICs, Battery Powered Class D SDS-254 Amp, and GR-Research N2X Speakers
  • orrb_05
    orrb_05 Posts: 215
    Are you going where I think you're going with this? As in ATi=Outlaw?
    praedet wrote: »
  • dorokusai
    dorokusai Posts: 25,627
    Anthem. The RTi12 is a surprisingly power hungry loudspeaker even at 90dB and 8ohm. The Outlaw will work fine but they open up much better with a 300wpc+ amplifier from my experience.
