SDA CRS+ 4.1tl upgrade question??
Toolfan66
Toolfan66 Posts: 18,055
edited November 2010 in Vintage Speakers
Can the 1986 CRS+ take the 4.1tl upgrade?? also if so does one have to put in the MW6511 drivers to complete the upgrade?
The 1986 CRS+ take all MW6510 drivers..
The 1987 CRS+ take two MW6503 & two MW6511
The 1989 CRS+ take two MW6511 & two MW6510
So is the 1989 CRS+ the only set that can take the 4.1tl upgrade? as the Schematic's call for the MW6511 & MW6510's
And yes I have the 1986 CRS+ version..
Thanks!!!
Larry.
Post edited by Toolfan66 on
  • gimpod
    gimpod Posts: 1,793
    Larry I think you could do it but you would have to re-do the tweeter circuit, You would need to remove the 2.7 ohm resistor that's in series with the 0.4mh inductor and jumper it them put a 5.8uF cap across the other 2.7 ohm resistor. Then all you have to do is slap a RDO-198 in. I don't think the drivers make a difference in doing the TL upgrade but I could be wrong too.:rolleyes: ~ gimpod
    F1nut Posts: 51,763
    ^What he said^
    Thanks guys!!
    I figured as much and tried the search but it would not bring anything up.
    The only thing that had me ask was the drivers when I looked at the 4.1tl schematics.
  • Face
    Face Posts: 14,340
    6510's may have a different roll-off, it's possible the shunt 2.7ohm resistor may be there to compensate. No way to tell without confirmation from Polk or if someone could measure a 2A or 1986 CRS+.
    Well the nice thing "if needed" I have MW6511's in stock :) two of them that I have came out of CRS+'s ;)
  • Joe08867
    Joe08867 Posts: 3,919
    Keep the resistor. I tried removing it from my SDA2's and ended up having a mid-range loss that was weird. I think the Face hit the nail on the head. The 6510 has a big rolloff that the tweeter compensates for.
    They fixed it in later versions with the 6511's..
  • brgman
    brgman Posts: 2,859
    Whats a 4.1Tl upgrade?
    I’M OFFENDED!!!!
  • Joe08867
  • FTGV
    FTGV Posts: 3,650
    Since the component values in the 6511's filter section are exact multiples(inductance is halved,shunt capacitance doubled)might indicate it is a 4 ohm driver vs 8ohm for the 6510& 6503?
