SDA CRS+ 4.1tl upgrade question??
Toolfan66
Can the 1986 CRS+ take the 4.1tl upgrade?? also if so does one have to put in the MW6511 drivers to complete the upgrade?
The 1986 CRS+ take all MW6510 drivers..
The 1987 CRS+ take two MW6503 & two MW6511
The 1989 CRS+ take two MW6511 & two MW6510
So is the 1989 CRS+ the only set that can take the 4.1tl upgrade? as the Schematic's call for the MW6511 & MW6510's
And yes I have the 1986 CRS+ version..
Thanks!!!
Larry.
Thanks!!!
Larry.
Post edited by Toolfan66 on
Larry I think you could do it but you would have to re-do the tweeter circuit, You would need to remove the 2.7 ohm resistor that's in series with the 0.4mh inductor and jumper it them put a 5.8uF cap across the other 2.7 ohm resistor. Then all you have to do is slap a RDO-198 in. I don't think the drivers make a difference in doing the TL upgrade but I could be wrong too.:rolleyes: ~ gimpod“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
^What he said^Political Correctness'.........defined
President of Club Polk -
Thanks guys!!
I figured as much and tried the search but it would not bring anything up.
The only thing that had me ask was the drivers when I looked at the 4.1tl schematics. -
6510's may have a different roll-off, it's possible the shunt 2.7ohm resistor may be there to compensate. No way to tell without confirmation from Polk or if someone could measure a 2A or 1986 CRS+."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Well the nice thing "if needed" I have MW6511's in stock
two of them that I have came out of CRS+'s
Keep the resistor. I tried removing it from my SDA2's and ended up having a mid-range loss that was weird. I think the Face hit the nail on the head. The 6510 has a big rolloff that the tweeter compensates for.
They fixed it in later versions with the 6511's.. -
Whats a 4.1Tl upgrade?Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
This schematic is what they are talking about.
http://www.polkaudio.com/forums/attachment.php?attachmentid=26710&d=1186358580 -
Since the component values in the 6511's filter section are exact multiples(inductance is halved,shunt capacitance doubled)might indicate it is a 4 ohm driver vs 8ohm for the 6510& 6503?
