Help identify this speaker wire
Earthy
Earthy Posts: 488
A friend gave me this speaker wire. It's 16 18g wires braided. The bundle is about 1/2" in diameter. It's not hand wound, so I figure someone has run across it before and can comment on it. I was planning to do short 2 meter runs.
Polk Audio SDA SRS 2.3TL
Parasound Halo A21
Parasound Halo P3
Home theater
Polk LSiM 707, 706c, 703, 705
Polk Blackstone TL3 for height
SVS PB12-ISD Sub
Denon AVR-X6400h
Parasound Halo A51
LG OLED65B7A
Sony UBPX800
Logitech Harmony Elite
PC LSiM 703
Spare LSIM 702 and 706c
Home Theater #2
Polk Audio LS70, CS350LS, LSF/X, S4
Onkyo TX-NR808
Post edited by Earthy on
  • thsmith
    thsmith Posts: 6,082
    edited November 2010
    Kind of looks like Kimber Kable.
  • messiah
    messiah Posts: 1,790
    Looks like an old version of Kimber 8tc. They don't make the black and blue anymore. Very good stuff! Nice friend!
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • Earthy
    Earthy Posts: 488
    Interesting. I have a bunch of the black and grey 8 wire ones too. That's what I currently have on my SDA's. Leftovers from my Dahlquists. Guess I need to find some quality spades/bananas and some jacketing to dress it up.
    Thanks folks!
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • Earthy
    Earthy Posts: 488
    edited December 2010
    I bought some locking GLS spades with set screws. That's obviously not the best way to terminate wire like this. I suspect some type of crimp connector would work better.
    Any thoughts on what might work best? Having 8 wires per side makes it interesting.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • nguyendot
    nguyendot Posts: 3,594
    Solder something nice on....
    Main Surround -
  • Earthy
    Earthy Posts: 488
    I gave it another shot and stripped the wire back about an inch so I could better twist all the pairs together. I put some heat shrink on to hold them. Then trimmed them shorter. That seemed to work, so I spent the last couple of hours finishing one 6' cable. My 18mm hs was shrunk to the limit. Need something a tad smaller, but it will do. I'll go ahead and do the other one with the materials I have on hand.
    Parasound Halo A21
    Parasound Halo P3
    Home theater
    SVS PB12-ISD Sub
    Denon AVR-X6400h
    Parasound Halo A51
    LG OLED65B7A
    Sony UBPX800
    PC LSiM 703
    Home Theater #2
    Onkyo TX-NR808
  • jimmydep
    jimmydep Posts: 1,305
    Looks nice and neat, hope they sound a good as they look.
  • Beta
    Beta Posts: 267
    My thoughts as well. Looks like the past version of Kimber 8TC. Nice cable.
  • fbm211
    fbm211 Posts: 1,488
    get some Xhadow bananas plugs for that cable,it deserves the good stuff.If there too expensive than I would recomend furez banana plugs.There pure copper or silver plated pure copper.
    Link>> http://www.av-outlet.com/en-us/dept_149.html
    I terminated my Q-10 signature with the silver plated ones.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • djperez81
    djperez81 Posts: 388
    i wish i had nice friends like you have......mine dont give me anything for free:frown:
    looks like you did a nice job with them though.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
