Where to get these caps for binding posts
ecod123
I am looking for identical (or close to) replacement screw-in caps for binding posts like those in the pictures below. A couple are cracked and I would like to replace them. I tried Parts Express but they don't seem to have similar ones. Can someone point me in the right direction? Thanks.
Post edited by ecod123 on
What amp are they from?"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
They're from a DIY amp I bought used. The posts look similar to those on Rotel 10XX and Emotiva XPA series amps.
you could check sonic craft,and parts connection,SDA-2BTL with custom IC
Harman Kardon T-55c TT
DH LABS REVELATIONS ICs-amps
Revelation Audio Labs Paradise cryo-silver ICs-Source to pre -
Thanks!
Funny, they don't seem to carry the ones I am looking for despite having a wide selection.
They all have the full metal ones, but not the plastic encased ones I am looking for.
Any DIYer's out there know where I can find the ones I am looking for? -
Do they look like these? http://www.superetrade.com/images/Amplifiers/YAQIN/MC%2010L/big/10L-0027.JPG
Maybe one of the Eb*y sellers of these amps could tell you where to buy them, Tubestein perhaps.SDA SRS 2.3TL's
SDA 2B TL's -
michaeljhsda2 wrote: »Do they look like these? http://www.superetrade.com/images/Amplifiers/YAQIN/MC%2010L/big/10L-0027.JPG
Yes, they look like those in your link. So what amps are these and who are the eb*y sellers? Can't find "tubestein" on eb*y. Do you have a link or perhaps search words? Thanks! -
http://www.dhgate.com/speaker-cable-tube-amplifier-terminal-binding/p-ff8080812b47d523012b48485d8562a7.html
http://www.dhgate.com/3pcs-speaker-cable-tube-amplifier-terminal/r-ff8080812b28a50c012b28f67f2658b1.html
they look like what you are looking for, but come in different options"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
Messiah,
Thanks for the links. Interesting ebusiness site. Has that eBay layout. The posts look similar to what I am looking for but in lots size, more than what I need. -
I've never seen the caps available by themselves. They're usually sold as a whole(binding post)."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Face, if needed, I wouldn't mind buying the whole binding posts to get the caps. The other parts can come in handy later. So where have you seen them? Thanks.
President of Club Polk -
Thanks for the link. These have that new clamping design where there's a notch and hole in the plastic cap. Was hoping to find some with that new design for consistency with the rest of my binding posts. $48 a post - maybe I should just live with my cracked caps for now. -
Thanks,Face! I saw those when I first checked PE but again they are the new design ones with the notch and hole for cramping spades and bare ended wires. $34.00 a pop have me rethinking. I may have to live with the cracked ones for a while. -
FYI, the plastic cover is only there to satisfy the European market requirements, it's not really needed and everyone of that type that I have seen crack over time. Therefore, any you replace now, will crack later.Political Correctness'.........defined
They're a PITA and I can't stand them either."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
The WBT binding posts are covered with Makrolon. If you know anything about polycarbonate you might reconsider your statement that they all crack.HT/2 CH
McIntosh MX120, MC500, MC206, MEN220
polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect. -
anonymouse wrote: »Look pretty similar to these: http://apexjr.com/Jacks.htm
Nice link, thanks. I got some of those for my amp at www.diycable.com on a closeout for $4 a pair. Very nice quality. When I went to order more they were sold out. Been looking for more ever since to put on the SDA's. -
No, I know nothing about Makrolon. Why don't you tell us about it.If you know anything about polycarbonate you might reconsider your statement that they all crack.
I did say "everyone of that type that I have seen crack over time", so it is entirely possible that I have not seen all of them.Political Correctness'.........defined
I don't need or find any usefullness in having a plastic cap on my binding posts. WBT makes everything from mild to wild and that binder is simply unneccesary.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Previously I worked for a small European company called ABB http://www.abb.com where we used Makrolon as a personal safety barrier in our switchgear and transformers. Just because it was impossible to crack. I have also done demonstrations for customers with me, sledge hammer and a sheet of Makrolon. No you can not crack it. Further a small car maker called "Mercedes" use it in headlights because it does not crack. Maybe we were all wrong.
I guess I misread your comment about that they will all crack. Sorry but English is not my first language.Therefore, any you replace now, will crack later.HT/2 CH
Dodd - Battery Preamp
ADS 1230 - Polk SDA 2B
Crown K1 - Subwoofer amp
Outlaw ICBM - crossover
Beringher BFD - sub eq
"I've always been mad, I know I've been mad, like the most of us have...very hard to explain why you're mad, even if you're not mad..." -
Bingo! Exactly what I am looking for. In stock, good prices. Another 2 great audio DIY sources for future references.
Thanks anonymouse and hoosier21!
