Where to get these caps for binding posts
ecod123
ecod123 Posts: 379
I am looking for identical (or close to) replacement screw-in caps for binding posts like those in the pictures below. A couple are cracked and I would like to replace them. I tried Parts Express but they don't seem to have similar ones. Can someone point me in the right direction? Thanks.
  • messiah
    messiah Posts: 1,790
    edited November 2010
    What amp are they from?
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • ecod123
    ecod123 Posts: 379
    They're from a DIY amp I bought used. The posts look similar to those on Rotel 10XX and Emotiva XPA series amps.
  • fbm211
    fbm211 Posts: 1,488
    you could check sonic craft,and parts connection,
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • ecod123
    ecod123 Posts: 379
    fbm211 wrote: »
    Thanks!
    Funny, they don't seem to carry the ones I am looking for despite having a wide selection.:confused: They all have the full metal ones, but not the plastic encased ones I am looking for.
    Any DIYer's out there know where I can find the ones I am looking for?
  • michaeljhsda2
    michaeljhsda2 Posts: 2,222
    Do they look like these? http://www.superetrade.com/images/Amplifiers/YAQIN/MC%2010L/big/10L-0027.JPG
    Maybe one of the Eb*y sellers of these amps could tell you where to buy them, Tubestein perhaps.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • ecod123
    ecod123 Posts: 379
    Yes, they look like those in your link. So what amps are these and who are the eb*y sellers? Can't find "tubestein" on eb*y. Do you have a link or perhaps search words? Thanks!
  • messiah
  • ecod123
    ecod123 Posts: 379
    Messiah,
    Thanks for the links. Interesting ebusiness site. Has that eBay layout. The posts look similar to what I am looking for but in lots size, more than what I need.
  • Face
    Face Posts: 14,340
    I've never seen the caps available by themselves. They're usually sold as a whole(binding post).
  • ecod123
    ecod123 Posts: 379
    Face, if needed, I wouldn't mind buying the whole binding posts to get the caps. The other parts can come in handy later. So where have you seen them? Thanks.
  • Face
    Face Posts: 14,340
  • ecod123
    ecod123 Posts: 379
    Thanks for the link. These have that new clamping design where there's a notch and hole in the plastic cap. Was hoping to find some with that new design for consistency with the rest of my binding posts. $48 a post - maybe I should just live with my cracked caps for now.
  • ecod123
    ecod123 Posts: 379
    Face wrote: »
    Thanks,Face! I saw those when I first checked PE but again they are the new design ones with the notch and hole for cramping spades and bare ended wires. $34.00 a pop have me rethinking. I may have to live with the cracked ones for a while.
    F1nut Posts: 52,406
    FYI, the plastic cover is only there to satisfy the European market requirements, it's not really needed and everyone of that type that I have seen crack over time. Therefore, any you replace now, will crack later.
  • Face
    Face Posts: 14,340
    They're a PITA and I can't stand them either.
  • Janne
    Janne Posts: 139
    The WBT binding posts are covered with Makrolon. If you know anything about polycarbonate you might reconsider your statement that they all crack.
    HT/2 CH
    McIntosh MX120, MC500, MC206, MEN220
    polkaudio SDA SRS 1.2TL, XO, Inductor, Tweeter, Larry's rings, WBT Binding posts, Moretite and Dynamat mod. Built by Mollie Jones 27:th of February 1991, CS350-LS XO mod, LS-f/x, DSW MicroPro 4000
    MIT Shotgun S3.3 Bi-wire SC, Shotgun S3.3 SC, Shotgun S3.3 Proline IC, Shotgun S3.3 IC, Shotgun S3.3 Sub cable, AVT 1 Optical IC, EXP 3 Speaker interconnect.
  • WilliamM2
    WilliamM2 Posts: 4,829
    anonymouse wrote: »
    Look pretty similar to these: http://apexjr.com/Jacks.htm
    Nice link, thanks. I got some of those for my amp at www.diycable.com on a closeout for $4 a pair. Very nice quality. When I went to order more they were sold out. Been looking for more ever since to put on the SDA's.
    F1nut Posts: 52,406
    Janne wrote: »
    No, I know nothing about Makrolon. Why don't you tell us about it.
    I did say "everyone of that type that I have seen crack over time", so it is entirely possible that I have not seen all of them.
  • dorokusai
    dorokusai Posts: 25,661
    I don't need or find any usefullness in having a plastic cap on my binding posts. WBT makes everything from mild to wild and that binder is simply unneccesary.
  • Janne
    Janne Posts: 139
    Previously I worked for a small European company called ABB http://www.abb.com where we used Makrolon as a personal safety barrier in our switchgear and transformers. Just because it was impossible to crack. I have also done demonstrations for customers with me, sledge hammer and a sheet of Makrolon. No you can not crack it. Further a small car maker called "Mercedes" use it in headlights because it does not crack. Maybe we were all wrong.
    I guess I misread your comment about that they will all crack. Sorry but English is not my first language.
    HT/2 CH
  • hoosier21
    hoosier21 Posts: 4,437
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • ecod123
    ecod123 Posts: 379
    anonymouse wrote: »
    hoosier21 wrote: »
    Bingo! Exactly what I am looking for. In stock, good prices. Another 2 great audio DIY sources for future references.
    Thanks anonymouse and hoosier21!
