test pic
gidrah
So tell me, is that a ST-70 you have sitting on the floor, along with some Altecs?
That system looks like you bought it at a pawn shop.;) nothing wrong with that thoughMy Setup:
Toshiba Theaterwide 51H83 HDTV
Yamaha RX-V3300 reciever
Yamaha CDC-585 cd
Sony Progressive Scan dvd
Wharfedale Evo-30 mains
Wharfedale WH-2 side/rear surround
Wharfedale Evo-Centre center
Polk PSW-404 sub
IXOS speaker wire and cables -
Obviously someone new to 'the hobby'.
That Dynaco / Altec combo will kick the snot out of your Wharfedale / Yammie setup.
Nothing wrong with that though.Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service. -
Yeah those Altecs are berry good. Are those 806 compression drivers in the horns by any chance? They must sound great combined with a tube amp. Me rikey.Graham
SWEET ! tubes and horns is awesome. I run them for my 2-channel audio system.
By the way, I'll be in Detroit (Southfield) on Feb 21 for a all day audio meet. You should come check it out and look me up. PM me for more info. -
Russ - Thanks. I'm sure he meant nothing by it though. Heck, I wish I had got it from a pawn shop. It probably would've been cheaper.
Gatemplin - Yes, they have the 806 drivers. 811 horns and 416 -8A woofers. Yep, the combo sounds great. Unfortunately the tubes have been moved again. Back to the single drivers.
Wardsweb - I'll be there.Make it Funky!
Gidrah, I asked because I have the same 806 driver and H811B horn and I likes it. I am going to use it when I get my tube rig someday.Graham
Originally posted by gatemplin
Looks good WW,
What are those speakers?
They are Altec A7-500 Voice of the Theater; 416-8C woofers, 802-8G compression drivers w/tangerine phase plugs and 511B horns. -
You bought grumpy's Mac... :eek:More later,
Tour...
Vox Copuli
You bastage...
Your first Mac?
Going on the VOT's?More later,
Tour...
Vox Copuli
OK, Ski...
More later,
Tour...
Vox Copuli
