Question on Wall and Ceiling speakers
wcwc
wcwc Posts: 3
edited October 2010 in Speakers
I haven't put together a surround system before, so I have a few questions. I think I have settled on the TCi series speakers. The ceiling in my room is 2x2 acoustical tiles (drop ceiling). Is it possible to install in ceiling speakers in these tiles? Due to the ceiling, a fireplace, and a projector screen, I don't have a place for a center channel speaker unless I get an acoustically transparent screen. Can a ceiling mounted speaker such as the TC80i serve as a center channel speaker?
Post edited by wcwc on
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited October 2010
    I wouldn't put a speaker on a 2x2 tile, but if you need to I would put a little bigger 3/4" plywood above the rack so the speaker is connected to this and not a tile. IMHO.
    Welcome to Polk Forums.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • messiah
    messiah Posts: 1,790
    edited October 2010
    Yeah, those tiles aren't very strong, you'd want some sort of reinforcement.
    "They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
    messiah, November 23rd, 2010
  • wcwc
    wcwc Posts: 3
    edited October 2010
    What about using the ceiling mounted speakers as a center channel?
  • wallstreet
    wallstreet Posts: 1,405
    edited October 2010
    I wouldn't go ceiling center unless it's a last resort. The speaker are firing down instead of toward the listening area. I have a bedroom setup where the L and R speakers are ceiling mounted, but my center is under the TV. It works for the bedroom, but it's still not ideal.
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited October 2010
    can you access the joist above the ceiling?
    RT1
  • wcwc
    wcwc Posts: 3
    edited October 2010
    yes, I can access the joists. The drop ceiling is under the truss supports for the floor above.
