FatMat
eloplayspolo
Has anyone here had any experience with FatMat 50mill or 80mill.
I am looking at doing 100% of my car minus the headliner and im considering purchasing either the 50 or 80 mill, prob the 50 because i can do 2 coats if needed and prob still have plenty for my car + i will be able to get it in places that dont have much room for fitting panels.
Do you guys know of another alternative which is competitive with the fatmat. I know we've had this debate 100 times here.
2013 Toyota Prius
Audible Physics 3 Way: H6MB, AR3-A, AR2.0
Image Dynamics iDMax 12" D2v4
(2) Alpine PDX-V9 Bridged, Alpine PDX-M12 (500w Mid-Bass, 200w Mid, 200w Tweet, 1200w Sub)
Mosconi 6to8 v8
Mosconi 6to8 v8
Post edited by eloplayspolo on
Cody, Mac, intaller4life: U guys got any recommendations?2013 Toyota Prius
Mosconi 6to8 v8 -
Never tried FatMat but also look into Second Skin and Raamat. I used both, both are great. SS is on the pricy side but well worth it imo.2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
Well, ive used dynamat extreme and it was great where i put it.
just looking for something cheaper and the fatmat is CHEAP2013 Toyota Prius
Mosconi 6to8 v8 -
fatmat is asphalt based last i checked...stay away from anything thats not 100% butyl.
Hushmat is 100% butyl and pretty cheap...check them out.
I got this coupon in my email the other day for secondskin
Want to take 15% off of our biggest sound deadening package ?
First, click here to check out the product:
http://secondskinaudio.com/products/factory-five-cobra-roadster-sound-deadening-thermal-insulation-kit.php
Then use this coupon code to take your 15% discount:
ffcemail15
Thanks so much for your attention!"
thanks cody, i appreciate the coupon - just a bit out of my budget though...
im thinking this is a good deal!
http://cgi.ebay.com/ebaymotors/100-ft-eDead-Xtreme-Car-Sound-Deadener-Dynamat-Roller-_W0QQcmdZViewItemQQhashZitem53e44f47d1QQitemZ360312686545QQptZVintageQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_3011wt_909
hear anything about it?2013 Toyota Prius
Mosconi 6to8 v8 -
u know.... this one is intriguing... the advertising is very well done.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&_trksid=p4340.m656&item=220685727714&viewitem=&_trkparms=clkid%3D4499600616967891162#ht_5750wt_9772013 Toyota Prius
Mosconi 6to8 v8 -
If you get eDead I'll never talk to you again...haha.
But no seriously...if there's ever been a more piece of s#$t company out there...it's ED.
Never heard of zilla...did you look up hushmat?
exalted512 wrote: »If you get eDead I'll never talk to you again...haha.
But no seriously...if there's ever been a more piece of s#$it company out there...it's ED.
-Cody
While i agree with you on eDead but if u're talking about their subs as well i'm gonna have to ask for an explanation lol
2008 Nissan Altima
Kenwood DNX 5140
Not as much as the products as it is the company, and specifically, its **** bag of an owner.
But eDead really is crap.
**** bag owner = db company = db product. Simple logic
exalted512 wrote: »Never heard of zilla...did you look up hushmat?
-Cody
did you see their picture on ebay! looks good
everything seems pretty retarded expensive. dynamat bulk packs can be had for 130, with like 36 square feet, hushmat was more when i looked on a few sites.2013 Toyota Prius
Mosconi 6to8 v8 -
Some sound deadening is better than no sound deadening. You could give the zilla stuff a try and see how it works out...then let me know...haha.
exalted512 wrote: »Some sound deadening is better than no sound deadening. You could give the zilla stuff a try and see how it works out...then let me know...haha.
-Cody
lol i have no interest in the product, i just though their product picture was hilarious.2013 Toyota Prius
Mosconi 6to8 v8 -
cant be any worse than eCrap
