SRT sub drivers need TLC. Need Advise
dpowell
dpowell Posts: 3,081
edited November 2010 in Troubleshooting
One of my SRT subwoofers has been making strange noises when hitting deep or at louder volumes. I thought at first the drivers might be bad and was going to send them to a shop that rebuilds drivers.
However, after removing them from the enclosure, I discovered that the source of the sound might actually be due to the glue coming loose from one of the components of each driver. I've taken some pictures showing which part of the drivers appears loose (I believe they are loose because sections are still glued while other sections are loose and there appears to be dried glue). I'm looking for suggestions on whether I have correctly diagnosed this problem and if so, what type of glue I should use to reglue them.
The rubber surrounds appear to be in great condition and the drivers themselves seem to move in and out without binding or creating unusual noise.
It's my understanding that there are no replacement drivers available so I want to do this right! :D
Thanks in advance,
doug
Post edited by dpowell on
  • ben62670
    ben62670 Posts: 15,969
    edited October 2010
    Looks like you need to glue them. I have used super glue for the job.
    Ben
  • dpowell
    edited October 2010
    Thanks Ben. Am I assuming correctly that the entire circumference (whatever that part is called) should be glued down?
  • ben62670
    edited October 2010
    Yes sir.
    Ben
  • kawizx9r
    kawizx9r Posts: 5,150
    edited October 2010
    dpowell wrote: »
    That'd be the spider Doug :)
    Can't wait to hear them, good thing Ben's taking care of ya!
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • leroyjr1
    leroyjr1 Posts: 8,785
    edited October 2010
    Wonder if anyone has ever tried replacing them with different/better subs?
  • dpowell
    edited October 2010
    leroyjr1 wrote: »
    Don't know. The 2 drivers inside each sub are not identical and are wired serially. I'd be interested if Ken or someone else from Polk has any thoughts on that.
    I have heard from another SRT owner that the subs really came alive when he switched to using external amplification as opposed to the built-in amps that came with the SRT subs. It appears to be an easy mod but I'd want to have a 2-channel powerhouse to drive them since they currently have 300w amps.
  • dpowell
    edited October 2010
    kawizx9r wrote: »
    Looks like I have a good weekend project....
  • ESavinon
    ESavinon Posts: 3,067
    edited October 2010
    Polk will fix them for you if you like.
    SRT For Life; SDA Forever!
    The SRT SEISMIC System:
    Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once.
  • ESavinon
    edited October 2010
    leroyjr1 wrote: »
    Not necessary. You can always upgrade the plate amps and the internal wiring.
  • dpowell
    edited October 2010
    ESavinon wrote: »
    Have you upgraded the plate amps in yours? If so, what modifications did you make? Replacing the caps seems like the most logical choice.
  • dpowell
    edited October 2010
    ESavinon wrote: »
    I'll give them a call. I think the service center is about a 15-20 minute drive from me. I'd like it done right.
  • ESavinon
    edited October 2010
    Oops, This is what I meant to write:
    Not necessary. You can always replace the plate amps with external amplification and upgrade the internal wiring.
    The rum is starting to kick in.
  • leroyjr1
    edited October 2010
    ESavinon wrote: »
    What kind of external amp would you have in mind?
  • ESavinon
    edited October 2010
    Any mono amplifier able to output 300+ rms that is stable to 2 ohms.
  • dpowell
    Polk CS advised me that they would fix the drivers if I sent them to the Baltimore offices or that I could use super glue as was suggested in the thread. I decided to give it a try myself. I'm satisfied with the outcome. The spiders seemed a bit brittle in places but glued back nicely. The sub sounds great again. Amazing how deep the SRT subs hit!
  • dorokusai
    dorokusai Posts: 25,576
    It's still one of the coolest loudspeakers Polk has made, even better than the SDA SRS1.2. I've yet to start modding mine but at some point I need to do it.
  • dpowell
    dorokusai wrote: »
    What kind of mods do you have in mind?
  • dorokusai
    Balls to the wall....because after their done, I'll pack them in a box and let them become more rare while I mess around elsewhere.
  • Vette C6.r
    Vette C6.r Posts: 1,560
    Two of my subs spiders have unglued themselves. Did the same thing. Superglue and done. I did not do the whole woofer however. I just did the spot where the glue came undone. Not sure if that is the correct way but I havn't had a problem since.
