Anybody think
MY SETUP SUX?! =/ do i need a sub or are the a7's enought wit 200wpc?! i mean they sound nice they punch nicely! but would the sub make a diffrence?!
Say a VTF3. MK3?! or sumthing like tht?! Or maybe if i get the emotiva xpa2 wuld it be hitting harder?! im gettin a good deal on the xpa2!! >=] shuld i pull the trigger ?! 300 for it! =O
Room Theater:
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Sub...svs pc13 ULTRA
Amp:Emotiva xpa3
Fronts:RTIA3
center; CSIA6
AVR: Onkyo 709
panasonic 55"plasma
Ps3 slim 250gb
surrounds.Fxia6
Amp:Emotiva xpa3
Post edited by Ericw2431 on
Considering your sig says you have an XPA3, stepping up to an XPA2 (for 100watts more) wouldn't be much of an upgrade IMO.
If you want a better amp, why not dump the XPA2 idea and sell the XPA3 and get an even better amp?
A sub will make a hell of a difference, especially for HT. Depends what your needs are really and the budget.
Will it be even 50/50 split between music/movies?Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
A sub makes all the difference in the world!!Klipsch RF7-II
Klipsch RC64-II
Klipsch RC62-II
Onkyo TX-SR805
Dish 722 dvr
Sony BDPS370 Blue Ray
Samsung 52b750 LCD Tv
Panasonic DVD Recorder -
your room has as much to do with sound as any upgradeSamsung pn64f8500
Sonus faber venere 2.5
Sf venere center
Oppo 105d
Squeezebox touch
Parasound hca1500a
Apc power filter
Audioquest cables asst
Polk rtia3 SB
Polk fxia6 sl,sr
Dual hsu vtf3 mk3 -
What's the efficiency rating on the A7's? Is your focus mainly movies?Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
A sub should help. How old are your speakers? Maybe they are still breaking in.Panny 55-st30 plasma
Pioneer vsx-1121
Parasound 2100 pre
b&k tx4430 amp
Oppo bdp-83
Monster HTS 3500
polk TSi500s Vr3 Fortress modded
polk CS20 center channel Vr3 Castle modded
polk Owm 3 surrounds
polk PSW505 -
I agree with the uselessness of the XPA3 in the OP's situation as you need to at least double the power wattage to gain a 3db.Considering your sig says you have an XPA3, stepping up to an XPA2 (for 100watts more) wouldn't be much of an upgrade IMO.
As far as the subwoofer, IMHO the only gain would be for HT use but not too significant for music unless the speakers are not bass capable. As long as a quality speaker can go down to at least 40hz, a subwoofer is simply luxury and therefore not a justified expense and of course not a good bang for the buck.
Cheers!
TKDARE TO SOAR:
