Why is the LSi line
only in 4ohms? Is there a benefit from not being 8ohms?
Post edited by acmf74 on
Using google's search on polk's site I came up with the following. There is probably more discussions. These links probably offer a good place to start.
http://www.polkaudio.com/forums/showthread.php?t=105814
http://www.polkaudio.com/forums/showthread.php?t=29350 -
Higher sensitivity and also most high quality drivers are 4ohms."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Agreed....the OP should look at the LSI line as the corvette of Polk's line up. You can get a 4 cyl. engine in a chevy, but not a corvette, nor would you want to.HT SYSTEM-
lsi 9's -
At the track I've seen some 4 cyl. engines put a beating on the corvettes.:D -
have seen and done it first hand.
LSi lineup looks really nice, have yet to hear them in person yet thomole' -
Of course when you modify something it can beat something at a higher price point.At the track I've seen some 4 cyl. engines put a beating on the corvettes.:D
To stay on topic, there are 6 and 8ohm tweeters that are on par with the Vifa ring radiator, but most are a little to a lot more expensive."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
