old amp and pair of monitor 4's advice please?????
K-daugh
someone recently gave me a custom built amp claims its two channel 100 watt per only problem is the inputs are basically just screws that im assuming you would wrap copper wire around (speaker wire) does anyone know how this would work ....i dont have high hopes ....also i need advice on dismantling a set of monitor 4's .....i wanna part them out ....also need help on pricing .....thanks guys appreciate any advice
Budget 5.1 H.T. Set Up
HK avr 247 - Adcom GFA-7605Mirage Bps 150i powered sub - 40"Samsung LCD ln40c530 - Sony Blu Ray Player BDP-S370 - Comcast digital hd box(motorola dcx3400)
Monoprice Premium Interconnects Monoprice Ultra Slim HDMI w/Redmere
Custom Jumpers
Post some pictures including with the lid lifted off so the insides can be seen. That would help a lot to see if there is "hope".
ok will do .....if my computer likes me today i was having issues uploading pictures .....it kept saying the file was too big ...i dunno ill figure it out ...also im not questioning the person who built the amp abilities because he was like an audio engineer for raytheon or something ....basically hes the real mccoy just not sure if the amp is usable in the "real world"......any advice on the monitor 4's...what will the parts sell for aproximate.....speakers are about a 6/10 will post pics of these as well....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
- Belkin PF60 Power Conditioner - Cs2 center channel - Monitor 60's fronts - Monitor 30's rears
-Knukonceptz Kord 10 Gauge Speaker Wire - Nakamichi Banana Plugs
Custom Jumpers -
heres some pics.......i thinkBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
i got it hooked up to the monitor 4s it sounds awesome.....lol i found the rca inputs on the sideBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
i got the 4's on the side of the road and the amp i rescued from the trash......not to shabbyBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
question is do i really wanna hook this up to my m60's.....right now everything is hooked up to the avr.....will i benefitBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
some pics of the 4'sBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
nutha one....my computer is only letting one at a timeBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
nutha oneBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
wow its only letting post like have the pics i take .....says fatal error blah blah on the other half ......i dont get itBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
some more ......i think i figured it out i have to crop every picture ......question remains do i sell the m4's.....how much could i get ......what if i parted them.....and do i use this amp to power my mains or my surrounds.....:Dthanks guysBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
the amplifier is a sanken hybrid audio amplifier 2 channel 100 w rms/channel built in 1974Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
just found the manuals and schematics .....wiring diagram etc...i believe it was a diy kit you could buyBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
How did you come to learn it is a Sanken hybrid, as you did not know it in your very first post?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
Conrad Johnson PV-5 w/mods
MF x-DAC V8, HAInfo NG27
NAD SS rigs w/mods
GIK panels -
i just found the manual and wiring diagrams....says it right on it .....it even has notes of the guy who built it ......of coarse its like a foreign language to me ..........transitors...fuses...phase reversal blah blah blah anybody hear of this kind of amp if so what was your experienceBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Yeah, I think you must have been posting right at the same time I was. Does the literature cite the model number?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
series si-1000g possibly......Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
sanken electric co..ltd..tokyo,japanBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
The reason as you have found, is that this site has a size restiction on the photos we can submit. Im not sure which program(s) you use to edit your pics? But you can choose to "resize" them in your edit window. In whatever program, size them down to at least 12.00 W x 6.00 H thats about 70,000 pixels/inch. That way you can send multiple pics. :cool:
As to your next question why sell them? Why not build a 2ch rig with the both? My .02 worth.
Regards,
Matt
Integra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
AudioQuest Jaguar 72v dbs ic's
AudioQuest type 8 wire
biamped to:
2-Hafler 9500 trans nova's
AudioQuest NRG-3 power cable's
dedicated AC line for
Tesla Plex 20a duplex receptacle
Panamax Max 7500 pro surge/line conditioner
SDA SRS 3.1 TL's modded...
spikes, rdo's, rings, dynamat, sonicaps, mills & aeon
Panasonic Viera G20 50" plasma
...SDA's are just like candy for your ears... -
Yeah I had thoughts about keeping them and rebuilding them and refinishing them as kind of a little project......also thought about making my 5.1 a 7.1 by adding these only problem is I won't be able to reap the benefits of 7.1. Without a blu ray ......because most dvds are 5.1 along with most cable stations......anybody know where I can go to get parts for these particular speakers.....and roughly how much would it cost to rebuild them .....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
just hooked everything up for the second time after cleaning and three out four fuses popped on the amp.......they are the originals ...Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
OK, I'm mystified.
--- In post 1 you were "given" a mysterious custom built amp.
--- Then in post 3 we learn the person who gave you the amp is said to be the "real McCoy", and an "audio engineer for Raytheon or something".
--- In post 5 everything sounds "awesome".
--- But then in post 6 you relate "got the 4's on the side of the road" and the amp was now "rescued from the trash". (what happend to the Raytheon dude?)
--- And in post 14 you magically "found the detailed, branded manuals and schematics .....wiring diagram etc".
--- Then after cleaning everything up, during your second listening session most of your fuses blow.
It's strange that your ever-changing story needed alomst 20 posts because you posted it 1 line at a time instead of as a paragraph or 2.
So what's the agenda? What in the world is going on here?VTL ST50 w/mods / RCA6L6GC / TlfnknECC801S
NAD SS rigs w/mods
GIK panels -
the deal is the raytheon guy was cleaning out his basement.....hence i saved it from the trash ......the monitors i got on the side of the road because a customer of mine was throwing them out and didnt realize what he had......when i hooked the amp up to the monitor 4's it sounded great when i attempted to hook it up to my 60's the fuses blew .....thats everything in a nutshellinspiredsports wrote: »OK, I'm mystified.
So what's the agenda? What in the world is going on here?Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
does that clear everything up.....im confused on your tone.....do you not believe me...why would i lie on a forum.....posted one line at a time because i was posting after i figured stuff out ......Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
and not to add more one liners but i was looking for advice, not judgement.....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
Super. My advice is . . .
- - - don't part out the 4's. Keep them intact and keep them, or sell them. They aren't making them anymore and in my humble opinion, it's almost sacrilegious to part them out.
- - - definitely build out a 2-channel rig
- - - the Sanken looks like a quality piece of vintage gear that could be modernized with some new caps, etc. and binding post. Get it restored and you'll probably have the only one in the US.
NAD SS rigs w/mods
GIK panels -
inspiredsports wrote: »Super. My advice is . . .
+1
Matt:DIntegra DTR 50.2 used as a preamp
Rotel RCD 1520 cdp
biamped to:
what you said about the sanken is very interesting ......any suggestions on what parts to replace and where to get them and or someone who could rebuild it i may do it myself.....kind of a beginner in this realm of audioism though......and yes your right the 4's sound really good and i should keep them ....should i even touch these, possibly give them a tune up .....Budget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers -
anybody wanna buy these speakers make an offerBudget 5.1 H.T. Set UpHK avr 247 - Adcom GFA-7605
Custom Jumpers
