PSW10 Subwoofer
NeilGabriel
NeilGabriel Posts: 1,487
edited October 2010 in Speakers
I want to give a sub a try and keep it in the family...the PSW10 is for sale near me for $150.....can't find it among the Polk products...
thoughts? it would be used for heavy duty HT movie/dvd concert use.....(smoke free of course)
ng
Post edited by NeilGabriel on
  • Jim Shearer
    Jim Shearer Posts: 369
    edited October 2010
    I have PSW-10. It works well for me as a music sub, but I think it lacks the power and frequency extension for serious HT use.
    Cheers, Jim
    A day without music is like a day without food.
  • eeagle
    eeagle Posts: 226
    edited October 2010
    Here's a Link
    Too high a price for used. Here's a quick search on new.
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
  • NeilGabriel
    edited October 2010
    thanks...will check things out.....see what other subs are in my area....odd to think of subs in Kansas....
    Polk Audio PSW505 this looks like a good option....great reviews...?????
    http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0/ref=sr_1_10?s=electronics&ie=UTF8&qid=1287345425&sr=1-10
  • djperez81
    djperez81 Posts: 388
    edited October 2010
    you shold be able to buy a new one online for about 100. i own one and use it mostly for movies and music and it performs pretty damn good for me.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • Upstatemax
    Upstatemax Posts: 2,844
    edited October 2010
    It's hard to beat the PSW505 for the price...
    To really beat it, you would have to spend over 2x the Amazon price.
  • djperez81
    edited October 2010
    i agree with upstate...... it just depends what your budget allows
    -Jimi Hendrix
  • eeagle
    eeagle Posts: 226
    edited October 2010
    If you are getting serious and wish to consider other than Polk you will find most threads on this board will recommend subwoofer-only manufacturers like Hsu: STF-2 and a SVS PB-10, Velodyne SPL.
    I bought a Acoustec Bic H-100 back in 2007. The H-100’s dimensions are approximately 17"H x 15"W x 18.25"D with a weight of 42 pounds. The single rear vented cabinet houses a front firing, graphite injected, 12" cone woofer. The H100’s internal amplifier provides 150 watts RMS (500 watts dynamic peak) of power output. The frequency response is 24Hz to 200Hz. Designed by Dr. Hsu. The H100 uses the same BASH amp as the HSU STF-1 (150w RMS / 500w peak). It was highly recommended over in the AVS forums.
    BIC America F12 apparently replaces the H-100 and Amazon has it for $183 shipped.
    SDA SRS 1.2
    Adcom GFA-5802
    Adcom GFP-750
    Sony DVP-NS999ES
