PSW10 Subwoofer
NeilGabriel
I want to give a sub a try and keep it in the family...the PSW10 is for sale near me for $150.....can't find it among the Polk products...
thoughts? it would be used for heavy duty HT movie/dvd concert use.....(smoke free of course)
ng
ng
Post edited by NeilGabriel on
I have PSW-10. It works well for me as a music sub, but I think it lacks the power and frequency extension for serious HT use.
Cheers, JimA day without music is like a day without food. -
SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES -
thanks...will check things out.....see what other subs are in my area....odd to think of subs in Kansas....
Polk Audio PSW505 this looks like a good option....great reviews...?????
http://www.amazon.com/Polk-Audio-12-Inch-Powered-Subwoofer/dp/B000092TT0/ref=sr_1_10?s=electronics&ie=UTF8&qid=1287345425&sr=1-10 -
you shold be able to buy a new one online for about 100. i own one and use it mostly for movies and music and it performs pretty damn good for me.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
It's hard to beat the PSW505 for the price...
To really beat it, you would have to spend over 2x the Amazon price. -
i agree with upstate...... it just depends what your budget allowsMusic doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
If you are getting serious and wish to consider other than Polk you will find most threads on this board will recommend subwoofer-only manufacturers like Hsu: STF-2 and a SVS PB-10, Velodyne SPL.
I bought a Acoustec Bic H-100 back in 2007. The H-100s dimensions are approximately 17"H x 15"W x 18.25"D with a weight of 42 pounds. The single rear vented cabinet houses a front firing, graphite injected, 12" cone woofer. The H100s internal amplifier provides 150 watts RMS (500 watts dynamic peak) of power output. The frequency response is 24Hz to 200Hz. Designed by Dr. Hsu. The H100 uses the same BASH amp as the HSU STF-1 (150w RMS / 500w peak). It was highly recommended over in the AVS forums.
BIC America F12 apparently replaces the H-100 and Amazon has it for $183 shipped.SDA SRS 1.2
Adcom GFA-5802
Adcom GFP-750
Sony DVP-NS999ES
