Right surround channel not working
HTguru1982
The right rear channel on my Yamaha RX-V1200 is fading in and out. Sometimes I get no sound at all and only when I turn the receiver off and back on, do I get it to work. And even then, the output is low. I've tried switching out speaker wire as well as swapping surround speakers and it's definitely the receiver. For the time being, I am using my back up RX-V630(no issues at all).
I've opened up the receiver to see if something came loose but I have no idea what I'm looking at. Is this an easy fix or will I have to take it to the shop? If so, any idea what it might cost to fix something like this?
Thanks in advance.
Thanks in advance.
Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD
Fronts: NHT 2.5
Center: NHT VS-1.2A
Post edited by HTguru1982 on
Since you've already done and proven your cables and swapped speakers. From what you are describing it might simply be some cold joint on the IC output. Unless you are really good at soldering, you might want to take your receiver to a good repair shop. I can't imagine such repair costing more than 50 - 100$???HTguru1982 wrote: »The right rear channel on my Yamaha RX-V1200 is fading in and out. Sometimes I get no sound at all and only when I turn the receiver off and back on, do I get it to work. And even then, the output is low. I've tried switching out speaker wire as well as swapping surround speakers and it's definitely the receiver. For the time being, I am using my back up RX-V630(no issues at all).
Thanks in advance.DARE TO SOAR:
Thanks for the help.Display: Sony 42" LCD
Fronts: NHT 2.5
Center: NHT VS-1.2A
